cam question
Old Feb 10, 2008 | 06:58 PM
blown 04's Avatar
Default cam question
Im wanting to buy my next mod this coming week, and its looking like a gt2-3
Can i get away with my stock verter? if i have to get one would a tt2600 be enough? also i did a search on this but did not get the answer i wanted. I also read someone ran into valve float with the ls6 springs with this cam. Sorry for all the questions, just want to do it right the first time
Old Feb 11, 2008 | 12:16 AM
Hawk179's Avatar
put atleast a 918 spring on it. You are boosting the motor which means good pressure behind the valves.
Dont worry about too high of a convertor, you make enough mid band and low end to get you going. I would go nothing more than a 3K stall if you plan on drag racing. If not, then stick with a stock stall or maybe around a 2600 stall. You will like how that drives better.
Rick
Old Feb 11, 2008 | 12:17 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Well proven cam with the Radix. Stock converter might be fine for a while. Definately do a good set of springs and rods.
Old Feb 11, 2008 | 05:09 AM
blown 04's Avatar
thanks guys for your answers im ordering the gt2-3, 918, comp rods, let the converter go for now. my wish is to not pull the converter till the tranny dies, then a tt2600.
Old Feb 11, 2008 | 05:56 AM
old motorhead's Avatar
The later Zo6 cam has about the same specs as the GT2-3. If you want something that mild, you can pick up the zo6 cams for next to nothing. You can get them for exactly nothing if you're near a shop that does a lot of work on vettes. They throw them in the dumpster all the time. If I were going to all the trouble to change the cam, I'd go bigger. I used the cam in my sig in my 5.3L with a stock converter and it worked fine. Mean idle and the radix will pump up the low and mid range of a bigger cam. Still gets descent mileage when I can keep my foot out of it.
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
