cam ?4a 5.3..
Old Jan 30, 2013 | 10:05 AM
gallo-lo's Avatar
Default cam ?4a 5.3..
Im putting together an stock 5.3l for boost, and I had this cam sitting at my shelf..
Comp cam
In - ex
620-589
293-293
239-240
113+5 lsa
Had heads refresh3angle valve job,and good springs.
Old Feb 2, 2013 | 06:26 PM
gallo-lo's Avatar
Anyone?!
Old Feb 2, 2013 | 07:58 PM
53bowtie's Avatar
Is this for a turbo or supercharger? In either case it seems a bit large for a 5.3 if I am reading the numbers correctly. Stock48 has proven you dont need a large cam in these engines to move out under boost.
Old Feb 3, 2013 | 08:41 AM
gallo-lo's Avatar
I'm going turbo.
Old Feb 3, 2013 | 09:23 AM
Chevy_King1500's Avatar
isky triple 12 cam is proven for turbo
look it up
Old Feb 4, 2013 | 09:17 AM
That cam is way too big if it is a 239°/240° .620"/.589" 113° +5° (108° ICL).
That looks like a normally aspirated cam for a street 402. And that ICL is weird.
You want something more like a 218°/218° .530"/530" 115° +2° (113° ICL). The MAX I would go on a turbo 5.3 is a 224°. You don't need huge lift numbers either as the heads probably will not flow that lift.
Old Feb 4, 2013 | 10:29 AM
gallo-lo's Avatar
Ok, thanks..
Old Feb 6, 2013 | 10:18 AM
gallo-lo's Avatar
So if I decide to use an lq9 ? Would the cam work? , I know someone has an lq9..
Old Feb 6, 2013 | 10:26 AM
TXSZ66AVLANCHE's Avatar
See the multiple replies above, same applies to the boosted 6.0
Old Feb 6, 2013 | 01:30 PM
gallo-lo's Avatar
Thanks.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
