Borg Warner S300 opinion
Old 10-06-2012, 12:56 PM
WPG
WPG's Avatar
Default Borg Warner S300 opinion
Hey guys,
Looking to build a turbo kit for my 5.3 ecsb 4x4. I really just want a fast, fun daily driver. Something I can tow a little with and still take it to the track occasionally. I would like really quick response over max power, I would be pretty pumped with 450 rwhp or so. When my 4l60e inevitably blows up I want to swap in a manual transmission so I don't really know if that will have any effect on turbo choice but just throwing that out there. I have a buddy that is selling a borg warner s300 66mm compressor 80mm turbine and a .91ar, would this be a decent choice? if you guys have other suggestions Im all ears.
Thanks a lot guys, Appreciate the help!
Old 10-06-2012, 01:05 PM
Slowest turbo build ever!
black00chev's Avatar
That would be a nice turbo. Just not sure how fast that 80mm turbine will spool up and reach full boost.
Old 10-06-2012, 01:22 PM
WPG
WPG's Avatar
he said it was an 80/73mm turbine so im not sure what both the numbers are for.
Old 10-06-2012, 01:42 PM
lglowe's Avatar
That'll be an awesome turbo the 66mm will limit you on big power but will spool quick and not choke out so fast with the 73 exducer
Old 10-06-2012, 01:55 PM
WPG
WPG's Avatar
Awesome, thanks a lot. I thought it would be pretty good. I don't plan on really going crazy with rpm, Do you think it would pull ok to about 6K? Thats all the rpm it will ever see for sure. I might put something like a triple 12 cam in eventually but don't plan on going to wild with this truck. Thanks again for your input.
Old 10-06-2012, 02:05 PM
Mod with training wheels
smokeshow's Avatar
That's a really good turbo for your goals.
Old 10-06-2012, 02:06 PM
ok, if its the 80mm inducer and 73mm exducer turbine it should spool fairly well then.
Old 10-06-2012, 02:12 PM
sprayedenali's Avatar
Do it do it!! It'll spool almost instantly and be able to make probably 600+whp
Old 10-06-2012, 02:30 PM
I have a gauge for that
Atomic's Avatar
Excellent choice
Old 10-06-2012, 04:16 PM
WPG
WPG's Avatar
Great, Thanks!!
Looks like I found my turbo. I will post results and pictures of course when I finally get it together.
Quick Reply: Borg Warner S300 opinion
