boosting over 100k...
Old Jul 23, 2010 | 09:27 PM
TIM Z's Avatar
11 sec. Truck Mod
Go for it man!
Have fun, a low mile 5.3 are 500 $ all day long. So if ya pop it no biggie.
I just dont like high mile lifters.
I did a cam swap on the 183,000 mile 5.3 that came in my truck and the lifters took a ****.
After i swapped the 6.0 in i tore down the 5.3 and the cylinders were perfect with crosshatching. Some one took care of the motor.
GM fuel injected V-8s are know for 300,000 or more depending on how they were treated.
Old Jul 23, 2010 | 10:34 PM
black00chev's Avatar
Slowest turbo build ever!
other then me recently (within the last 2years) running a 93 tune and having some fun, its been treated pretty well. never towed anything and the engine has always seen synthetic oil.
but like ive said, little concerned with how its feeling slightly sluggish down low so ill atleast get it checked out to see how long it might have lol.
my old 5.3 had 181k on the ticker before it was totaled.
Old Jul 23, 2010 | 11:52 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
138K here, pushing 12 psi. Do a prelim checkout, and if it's good, boost away!!
Old Jul 24, 2010 | 07:09 PM
fastnblu's Avatar
Originally Posted by Quik
motors dont know mileage they know abuse. I wouldnt be afraid of boosting a motor with high miles as long as it checks out fine
as for little low on compression what do you think boost likes? ...
Originally Posted by TIM Z
...a low mile 5.3 are $500 all day long. ...
$500 is pretty reasonable.
Tim, now I know why u asked me was I gonna replace lifters when we talked today.
Now that smokeshow (& others) said u might be losing compression because of all the wear & tear on it. That means boost will be pushing past the rings, too. I would do a compression check...I guess maybe I better check my compression, not cause i have 75k, but cause I hammer the **** outta my truck.
Rick_Vor said FI is tough on perfectly running engines. I won't disagree or comment on that, but so is NA, sray & turbos. I too think it's how the person "drives" it.
Old Jul 25, 2010 | 09:25 PM
Id kinda figure new lifters if i were to do a matching cam some day, springs as well of course.
Old Jul 29, 2010 | 10:44 PM
been meaning to add, anyone wanna recommend a turbo setup for a DD 5.3 4x4? ive tried doin some research and seems a 70mm should fit fairly well for 6-10#s and even better if i ever wanted 10-15#s.
Old Jul 29, 2010 | 10:47 PM
Quik's Avatar
5 year bitches!
for a true DD, id say a 67 or 70
Old Jul 30, 2010 | 04:57 PM
lets just say WAY more DD then it will ever see track time, unless i get hooked out there someday lol. also figuring a tc in the 2600-3000rpm range, if that helps factor in size at all.
Old Jul 31, 2010 | 12:11 AM
00Silv4.8's Avatar
if you can afford it, boost away. Talk to 53russell on here, he just had a boosted 5.3 for something like 20k miles I wanna say until it started blowing by really bad. I would play it safe if you dont have a lot of play room
Old Jul 31, 2010 | 12:38 AM
Mangled03gmc's Avatar
Baltimore Whore
Exactly what quick said. Miles means nothing, abuse is what takes a toll.. Give it a compression test. If it checks out ok, boost it.. But for general maint I would put a new timing chain in there, maybe, maybe lifters. Other then that have at it if all is good in a PM check Bigg ?? is what miles is on the trans, rear..
