boosted 408s come in this thread
Old Jul 26, 2007 | 09:18 PM
  #41
Quik's Avatar
5 year bitches!
yes them two have very fast trucks. and parish caught on the street wouldnt be pretty site for almost 100% of anything on the street
Old Jul 26, 2007 | 09:43 PM
  #42
parish8's Avatar
single digit dreamer
turbos are the way to go for big power. just turn the boost **** and you can turn it up to the edge of knock. put in some good gas and turn it up some more. no belt slip. a pair of 76's would be way too much turbo. my 70's are too much turbo. i liked my single pt88 for a killer street set up or if you went twins a pair of 61's.
a meth set up is real nice if your looking to run pump gas only.
Old Jul 26, 2007 | 09:47 PM
  #43
Quik's Avatar
5 year bitches!
would mounting one of those decently size turbos as a rear mount do any good? also would i be able to use any of my exhaust i have now with a rearmount. i know some like headers and some say manifolds are better for rear mounts
Old Jul 26, 2007 | 09:50 PM
  #44
parish8's Avatar
a killer exhaust system would be a waste on a rear mount set up. not sure how a big turbo would work in the rear. with a 408 it might work prety well.
Old Jul 26, 2007 | 09:55 PM
  #45
Quik's Avatar
5 year bitches!
now what way are most going with for heads? i know some are running stock 317s soem are aftermarket. im starting to get and idea on cost of this
Old Jul 26, 2007 | 10:05 PM
  #46
parish8's Avatar
it's your choice. some stock 317's will take you a long ways or 392's or whatever the hot ticket is these days. i have afr225's but i ran stock 6.0's for the longest time. i dont think the heads are a very good bang for your buck(on a turbo set up) considering how good the stock ones are. they are more of a all out max effort mod. if your just looking for 700-800 i wouldnt waste the money. with a stick/408/boost 700rwhp should be prety easy. i bet a single gts76 on the trick front mount kit would get you well over 700rwhp but you would want to fab up an intercooler. i got to 640rwhp with a t76(not gts76) thru a 4l80e/tcase/mostly stock 6.0 but this was with good fuel. to do it with pump gas that 408 and stick will help a ton.
Old Jul 28, 2007 | 09:43 AM
  #47
Quik's Avatar
5 year bitches!
i was thinking if i went twins i could possibly use the rest of my exhaust? have a set of logs made and have turbos right there. sell my Lts....do you have pics of yours parish? also what size turbos do you think and what dish should i go with for pistons. also what rpm range you turning
Old Jul 28, 2007 | 05:48 PM
  #48
Originally Posted by Quik
yea it breaks driveline ****, if someoen would buy my exhaust setup then possibly just go turbo
You have caught me at a very bad time but what would you have to get for your complete exhaust set-up? Will it fit around a 4L60E?
Old Jul 28, 2007 | 05:55 PM
  #49
Slowhawk's Avatar
LS1Tech Sponsor
A 408ci with a single S85mm turbo hit's 700+rwhp on straight 93octain no problem at all through a 4L80.Also only 8-10lbs of boost will do it.With a 3200rpm stall there is really no lag at all.Just floor it from a stop and roast them till you let off the gas
Old Jul 28, 2007 | 06:12 PM
  #50
Quik's Avatar
5 year bitches!
i have 1800 into the exhaust...it should fit around a 60e with no issues. as for price i have to seriously think about that one
