Boost and Timing
Old Dec 2, 2007 | 06:35 PM
BlackSSS's Avatar
Default Boost and Timing
Is 15 degrees timing too much for 7.5 lbs. off boost or 2.9 pulley?
Old Dec 2, 2007 | 07:01 PM
Mort's Avatar
Not sure with the radix but I am running 17* with 12 psi on the STS. Just give it a try but be sure to log and watch for KR. I think you may be able to go higher but I am not sure how safe it will be and will depend on how the rest of your tune is set up.
Old Dec 2, 2007 | 07:35 PM
BlackSSS's Avatar
yeah I am not experiencing any knowck ...at least for the few minutes I watched for it, but today for the first time I have some "missing/sputtering" at high rpm. Shortly after that I have a horrible metal to metal knocking/clicking/rattling sound I cannot tell wherhe the sound it coming from. I thought it may be where I have not retorqed the radix back down after it being on a couple of weeks, but did that and it still makes the sound. I don't think the speeds up with engine rpm....at least I can't hear it....????
Always something!
Old Dec 2, 2007 | 10:37 PM
WJ MARK's Avatar
Always something!
Does it sound like gravel hitting your hood, might be det. Im running 18 deg. on 10 psi.
Old Dec 2, 2007 | 10:47 PM
Last Call's Avatar
TOTM: January 2007
I dont think there is a basic formula for X amount of boost = X amount of timing. I dont think 15 degrees would be a problem, but a log is the only way to tell.
I would be sure to log and see if it is KR. The 2.9 pulley is deinately going to generate more heat. I hope the knocking is not internal engine damage.
Old Dec 3, 2007 | 02:33 AM
stock48's Avatar
9 Second Truck Club
Im running 15 deg with 7LBS on a 6.0, with a trick front mount with no KR.
Old Dec 3, 2007 | 08:06 AM
WJ MARK's Avatar
you got that turbo on there allready??
Old Dec 3, 2007 | 09:24 AM
thunder550's Avatar
High on diesel fumes
When you log it, don't trust what you see 100%. You need to listen too. I never pick up KR with the scanner at WOT, but unless I'm spraying methanol I can hear detonation happening. Make sure you listen too.
Old Dec 3, 2007 | 01:11 PM
BlackSSS's Avatar
Unhappy
Yeah I am detonating too! Its very audible, but just sometimes. The horrible grinding noise is less today, but I think I have tracked down where its coming from...the nose of the charger...
Old Dec 3, 2007 | 01:16 PM
stock48's Avatar
9 Second Truck Club
I just got it going over the weekend. I have been working on it for the last two weeks. I did a cam, 6.0, 4l80E, 3.42 to 3.73 swap. Was alot of work I will be heading back up there on tuesday.
