Boost spike, need some insight.
Old Oct 6, 2016 | 07:23 PM
fctry286's Avatar
Default Boost spike, need some insight.
So i just finished getting my kit dialed in. Problem i am having is my boost is creeping up. 3rd gear ill get like 14lbs and then 4th ill hit 16.5lbs 5th it will go up to 18lbs. I have a turbo smart manual boost controller. Will getting the electronic one fox this?,i just want 16lbs through all gears.
Old Oct 6, 2016 | 09:26 PM
GRRR65GTO's Avatar
What about just running on wastegate spring? Does it creep or stay fairly even?
Old Oct 6, 2016 | 09:29 PM
fctry286's Avatar
When i ran just waste gate spring it was pretty consistent. It would still creep up a little.
Old Oct 6, 2016 | 10:38 PM
JordanH's Avatar
Restricted
Sounds like you need a larger wastegate. If you're still getting boost creep of spring pressure alone, then I'm pretty sure your wg isn't big enough to bypass the excess exhaust gasses in the longer gears/higher rpm.
Old Oct 6, 2016 | 10:55 PM
Atomic's Avatar
I have a gauge for that
An electronic one will certainly help. The wastegate needs to be able to adjust based on backpressure and boost. Manual controlls just give you one ratio the whole time but an electronic one can vary it as needed.
Old Oct 7, 2016 | 06:57 PM
fctry286's Avatar
Do you recomend an electronic boost controller?
Old Oct 7, 2016 | 11:27 PM
Atomic's Avatar
One in particular? I like the eboost street, eboost2, and boost leash. The only one I have used and didnt like was the SCG-1. If go with the eboost units (or any other "normal" electronic boost controller) I highly recommend using the 4 port solenoid instead of the normal 3 port one. The 4 works much much better.
rjw
Jan 7, 2018 01:41 PM
turboal1
Sep 29, 2016 10:58 PM
snogoer
Sep 20, 2016 12:21 PM
$A_Money$81
Sep 17, 2016 02:34 AM
go-on3
Sep 12, 2016 01:34 PM
