Boost psi
Old Sep 14, 2016 | 02:23 PM
turboal1's Avatar
Default Boost psi
If i use the stock 2011 6.2 truck crank pulley and the stock
LSA pulley how much boost will i see ? does the cam
make a diff in boost Psi ?
Old Sep 14, 2016 | 03:49 PM
Atomic's Avatar
I have a gauge for that
How big is the stock LSA pulley? I thought from the factory they made 6-7psi but I could be wrong.
Cam may make some difference in boost, but not much.
Old Sep 14, 2016 | 10:35 PM
turboal1's Avatar
Default Boost
Sorry,stock LSA pulley is 2.95 I thought stock was around 8.5 psi
I was told our truck crank pulley is smaller than a ZL1 or a CTS-V
LSA 9.1 Dia i read some where.
Old Sep 27, 2016 | 01:06 PM
turboal1's Avatar
Bump for some help
Old Sep 27, 2016 | 01:10 PM
Atomic's Avatar
6.2L, tvs1900 rotor set (1.9L), 2.95" blower pulley, and stock truck pulley (7.24"), would be a boost of 5-6psi. With a 10% OD crank pulley it would be 7-8psi.
Old Sep 27, 2016 | 02:16 PM
turboal1's Avatar
Default Psi
Thanks Atomic. looks like i need that 10% to hit
my 8 psi goal or find a bigger lower, ZL1 or CTS-V
Old Sep 27, 2016 | 05:42 PM
musclecity85's Avatar
you can run a 2.5 upper and it will put you at about 10.5lbs..thats what i run on my setup with longtubes, and an exhaust. also the zl1 and ctsv use the same supercharger(lower)
Old Sep 28, 2016 | 10:43 AM
turboal1's Avatar
Default pulleys
what could happen if i swapped out the bottom crank pulley 7.24 od
to a ZL1 crank pulley 9.1 od. besides everything running faster ?
Old Sep 28, 2016 | 10:48 AM
Atomic's Avatar
I don't think that pulley will fit without running the zl1 waterpump because of the pulley size on the pump.
Old Sep 28, 2016 | 11:08 AM
turboal1's Avatar
Default Pulley swap
I'm going to check that out, thanks Atomic
just looked at my truck, your right, won't fit.
not enough room. have to buy a top pulley,
damm new they cost a lot. hope i can find a used one.
What size/od would a top 10% pulley be ?
