Boost with radix questions?
Old Jan 15, 2006 | 03:21 PM
BLASTER's Avatar
Default Boost with radix questions?
I have a Radix on my 6.0L with a with my 3.2" pulley & I what to just verify a few things
I see:
-18psi vaccuum @ idle
~ -10ps1 vaccuum @ cruise
it gets less and less as I increase the throttle
Correct, right?
Then I can usually see:
+1psi boost with some more throttle
+3/4 psi boost with most throttle
+6/7 psi boost with full throttle
Max I ever saw was +7psi
Correct right?
I already have the Electrical guage hooked up but now I'm thinking I should have went Mechanical for more accuracy and could have saved a few bucks.
Would it be worth it to switch?
If not worth the switch, can I also cut and shorten the vaccuum hose that came with the electrical guage. I have it rolled up right now but could shorten it a good bit.
Thanks,
Kevin
Old Jan 15, 2006 | 03:35 PM
wkdivr's Avatar
Everything sounds about right. I would stick to the electrical gauge because you can integrate it into any data logging software you might get in the future.
Old Jan 15, 2006 | 04:04 PM
BLASTER's Avatar
Awesome. Knew I went with that for a reason. Just couldn't remeber what it was. Thanks man.
So should I just shorten the vaccuum hose it came with or just get some different hose?
I've read of it not being the best (kinks ect.) & some people getting different hose.
Old Jan 16, 2006 | 09:47 AM
Mort's Avatar
Cool
The vacuum hose can be cut to the length needed to suit your installation. Try to mount your pressure sensor that connects by wires to your gauge away from engine heat and vibration.
At idle I would guess you are seeing -18 inch of mercury not -18 psi of vacuum. It looks to me that your gauge measures Boost in PSI and Vacuum in Inches of Mercury. My truck runs -9.xx psi of vacuum at idle.
1 pound/square inch [absolute] = 2.036 020 658 inch of mercury [0 °C]
OnlineConversion
Old Jan 16, 2006 | 04:27 PM
BLASTER's Avatar
Cool. Thanks!
GXPJAY
Feb 13, 2022 08:15 AM
USMCvet0311
Aug 1, 2015 07:45 AM
sTNT971
Jul 16, 2015 12:39 PM
