Boost questions.
Old Jun 9, 2013 | 07:49 PM
05 vortec high output's Avatar
The cam I have now it's the cheaTR V3 cam from thunder racing.
Old Jun 9, 2013 | 08:32 PM
What if I get my 317 heads ported n polish? Would it help??
Old Jun 9, 2013 | 08:46 PM
03sierraslt's Avatar
It will help power a bit but end up lowering boost to some extent.
Old Jun 9, 2013 | 08:47 PM
Chevy_King1500's Avatar
it would help yes, but in forced induction you do not need to best heads to get big power, you are forcing the air in not sucking it in like on a n/a engine.
Old Jun 9, 2013 | 08:48 PM
Keep the same heads. Get the 10% overdrive crank pulley. N 8rib kit.
Old Jun 9, 2013 | 08:52 PM
Joe @ Leftcoast32 has some sweet 8 rib setups, that is where I got mine. His website is under construction but it has his contact info and he is on this board as a sponsor.
Left Coast 32
Old Jun 9, 2013 | 09:05 PM
Atomic's Avatar
I have a gauge for that
I ran a tvs1900 on a 408, it was great. Only made ~7psi with the smallest pulley, but that was plenty. Roots blowers actually work better the lower the boost is.
Old Jun 9, 2013 | 09:08 PM
swift700's Avatar
If you have an engine bigger than a 6.0 then I'd recommend a 2300 blower. The 1900 makes good power spinning the **** out of it on a bigger engine but it's more suitable to a 5.3 or 6.0. Like the other guys, I'd stick with your 6.0 and put some pulleys on it. With high-revving pulleys, a good exhaust, intake and cam you'll make some really impressive power. Your transmission will be living on borrowed time.
Old Jun 9, 2013 | 09:43 PM
Thinking adding like a 75 shot with meth. Maybe a lil better
BCraven1018
Nov 2, 2015 07:18 AM
BCraven1018
Sep 18, 2015 08:57 PM
lsxperformance
Sep 15, 2015 10:22 PM
2500ZL1
Sep 12, 2015 03:50 PM
Forcefed81
Sep 8, 2015 10:02 PM
