Boost Increase
Old Feb 21, 2008 | 09:00 PM
MikeGyver's Avatar
Default Boost Increase
Tonight, it topped out at 11.7 psi. I thought it was a fluke a couple of days ago when I saw more than 10. It started out in the 9 neighborhood after a couple of tanks of gas with the new motor. I am thinking that the severe oil blowby problem that I am soon going to remedy is the culprit. We tore the oil baffles out of my valve covers for the new rocker arms, and I am running PCV. I ordered an LS6 valley cover, I hope it fits. For now, I have an air-compresser coelescing filter in the PCV line. It fills the 2 oz. cup in about 100 miles. I was too lazy to empty it before tonight's test, and the blower probably got a few gulps of oil. I drilled and tapped the blower's intake elbow for a fitting to introduce PCV, because it's the only place that sees only vacuum, never boost. All this explanation leads to my question:
Does anybody else think that the oil would cause my boost to rise? I mean, if enough got into the blower, could it improve the seal enough to get 3 more psi? I know screw-type air compressors are oil sealed. Yes, I was getting a lot of KR, running 10.9-11.2 AFR. OK, my typing finger is sore.
Old Feb 22, 2008 | 01:39 PM
MikeGyver's Avatar
If my cats were getting clogged, it couldn't possibly run this good. (?)
Old Feb 22, 2008 | 03:29 PM
03sierraslt's Avatar
Cats? What are those? Oh ya those furry little creatures. Its possible the oil acted as a seal like you were describing.
gaps
Oct 15, 2015 02:53 PM
Rockrz
Sep 13, 2015 12:22 AM
2500ZL1
Sep 12, 2015 03:50 PM
muncie21
Sep 7, 2015 09:55 PM
