boost guys help
Old Apr 12, 2007 | 07:53 PM
jow02327's Avatar
Default boost guys help
06 silverado, 5.3 and procharger at 11-12 psi under full boost it is blowing the dipstick out. i know its over pressurizing the crank case but how do i fix it?
Old Apr 12, 2007 | 08:58 PM
parish8's Avatar
single digit dreamer
a new forged number 7 piston that doesn't have a crack in it......
sounds like you might have messed up the motor a little. do a compresion test and see how it looks.
Old Apr 12, 2007 | 09:00 PM
SCIV's Avatar
Did you pull the evap lines or are they still tied to the throttle body?
Old Apr 12, 2007 | 10:05 PM
Blown06's Avatar
8 Second Truck Club
Thats exactly the what happened to mine. #7 fried.
Old Apr 12, 2007 | 10:11 PM
1SlowHoe's Avatar
Destroyer of Transmissions
#7 is
Old Apr 12, 2007 | 10:17 PM
Do as Parish did and evac the crankcase via the pass side valve cover to the exhaust and filter the drivers side valve cover.
Old Apr 12, 2007 | 11:41 PM
Spires's Avatar
what exactly is the layout of the piston numbers?
Old Apr 12, 2007 | 11:44 PM
1SlowHoe's Avatar
Drivers side odd. #1 close to the radiator and #7 close to the firewall. (1,3,5,7)
Pass side Even. #2 at the radiator and #8 at the firewall. (2,4,6,8)
Old Apr 13, 2007 | 12:22 AM
MrXerox's Avatar
Pull the procharger off and take it into the dealership and go
Old Apr 13, 2007 | 09:55 AM
johnrusso1987's Avatar
Would this situation cause a misfire?
