Boost gauge on radix?
Old Aug 23, 2007 | 06:40 PM
bagged7104SS's Avatar
Default Boost gauge on radix?
I got a mechanical Auto meter boost/vacum gauge for my radix. It came with a T fitting to splice into a vacum/boost line. I am not sure which line to tap into. Does anyone have a pic of there radix setup?
Old Aug 23, 2007 | 08:54 PM
FastCrewCab4x4's Avatar
Theres a hose barb stickin "UP" all the way at the back, by the firewall, lookin at it from the drivers side. a little hard to get to, but it's workin fine. there, you get boost and vacuum. if you go by the TB you only get vacuum. I don't know of anywhere you can "T" off of for a source.
Old Aug 24, 2007 | 10:31 AM
I guess it is the one with the black rubber cap, not the brass fitting.
http://i64.photobucket.com/albums/h1...1/DSC02540.jpg
Old Aug 24, 2007 | 10:40 AM
Yep, It's like a 1/8 hose barb.....
Old Aug 24, 2007 | 11:35 AM
danv's Avatar
Default T tap
On my '03 the barb fitting that you show in your picture is where you get the vac/boost for the fuel pressure regulator. Using the "T" in that line (from the barb to the regulator) to get your boost pressure reading on a gage...
d
Old Aug 24, 2007 | 12:04 PM
Thanks for the help guys. I am going to try to install it later today.
Old Aug 24, 2007 | 12:26 PM
BlownChevy's Avatar
blownerator
25 Year Member
everyone above is correct.
GXPJAY
Feb 13, 2022 08:15 AM
chopperloco
Jul 10, 2016 10:45 PM
thunder550
Oct 8, 2015 04:53 PM
Ls3silverado
Jul 31, 2015 04:22 PM
