Boost gauge 2002 silverado
Old Nov 29, 2016 | 09:16 PM
Chevyguy02's Avatar
Registered User
Default Boost gauge 2002 silverado
So im getting a maggie tvs1900 soon and have my gauges already installed and functioning. Well my vac hose from my gauge is wired through firewall but isnt long enough to run to my manifold. So i wont he able to use the port on the maggie itself. So then i looked at tapping into brake booster but the t fitting that came with the gauge is too small to fit the brake booster. I went to the auto parts store to look for a t fitting but no luck. What exact fittong goes in that hose? 1/2" or 3/4" ?
Old Nov 30, 2016 | 09:30 AM
turboal1's Avatar
Default Line
I would just extend my boost gauge line
to reach the new port
Old Nov 30, 2016 | 10:55 AM
shootermwc's Avatar
^^^^Same
Old Nov 30, 2016 | 10:56 AM
shootermwc's Avatar
I actually had plenty of line on mine, but still managed to kink it on a sharp bend. Cut the kink out and made a little elbow. No problems
Old Nov 30, 2016 | 11:06 AM
Chevyguy02's Avatar
Registered User
where is a good place to get vacuum hose?
if I can find a t adapter at home depot ill just do that to the brake booster. closer to where I have it coming out of firewall and less points of failure.
Old Nov 30, 2016 | 03:18 PM
Atomic's Avatar
I have a gauge for that
You can just use a hose splice. Normal rubber hose will work fine since it will be such low pressure.
Old Dec 2, 2016 | 09:50 AM
turboal1's Avatar
Default Line
not a fan on putting it in the brake line.
Old Dec 2, 2016 | 12:32 PM
Chevyguy02's Avatar
Registered User
I already did it in the brake booster line and it works. next up im putting in shift kit and servos.
