Boost the Boost
Old Aug 23, 2005 | 02:22 PM
KySilverado's Avatar
Originally Posted by vanillagorilla
I see that your cam has 4* advance ground in it, I assume you installed it straight up though right?
What springs are you running? Is there any belt dust on the pulleys? Have you hooked up a different boost/vac gauge at all to see if its your guage? 3psi is sure a big diff. from a cam like that.
CompCams 918 springs, no sign of slippage, dust. Straight steady boost. I've not hooked up another gauge, never gave it a second thought.
edit: yes cam installed straight up with 4 degree advance ground in.
Old Aug 23, 2005 | 03:06 PM
Fogle07's Avatar
put a 2.75 pulley on it and let her rip
Old Aug 23, 2005 | 03:16 PM
I like your blatant disregard for the longevity of my expensive equipment.
Old Aug 23, 2005 | 03:20 PM
Fogle07's Avatar
either way it voids the radix waranty dont it?
Old Aug 23, 2005 | 03:23 PM
Yes, which was voided when I put the 3.25 on it technically. At 2.75 it would probably be my engine letting go not the radix.
Old Aug 23, 2005 | 03:24 PM
Fogle07's Avatar
what does that raise it up to? 10psi (2.75) i think im wrong about that though. i would put a 10lb pulley on it, whichever that is and ride
Old Aug 23, 2005 | 03:26 PM
I'm thinking the 3.1 will get me to 9-10 psi. Unless something is wrong. 2.75 guessing at 12-13 psi.
Old Aug 23, 2005 | 03:50 PM
Now you guys have me worried. I am going to have a look at my crank pulley. Mark it to make sure it isn't spinning.
Old Aug 23, 2005 | 08:38 PM
Given it the good look over. No evidence of belt slip. No evidence of balancer pulley turning. I am confident the boost gauge is correct. Truck runs great, solid steady instant boost to 6 maybe 6.5 at shift. No studders, no surges, good steady pull. I lost 2 to 3 psi boost when I installed the cam. I guess installing the new pulley will be the true test. Wish I had it tonight. The air is great
Old Aug 23, 2005 | 09:32 PM
BigBlackAv's Avatar
where is the best place to by a pulley?
