Bolt On Coolant Tank for turbo guys
That's same as low level, correct? If so, good info.
Interested in what lb cap your using aswell, I have an aftermarket tank aswell and it always pushs water out the over flow line when I rev up to 6500, but I think I might have mine mounted a little low too, idk if that would cause it.
It didn't come with a cap. He checked and the factory cap is 15PSI, the same as the mustang so went with that for like 10-15 bucks.
Here is underside shot. You can see it don't hold much and is a pretty light piece. You could fab a bracket if you felt you needed to, but I don't predict any issues with just the top two. The lower coolant line act as a vibration support from the bottom and it tabs are thick enough up top to keep it pretty firm. You do have adjust the tabs maybe a 1/8" bend down to clear hood a little more but nothing crazy.
