Blowing oil out
Old Oct 20, 2009 | 08:51 AM
ducky's Avatar
Default Blowing oil out
I believe I may be blowing oil out from the oil cap, it never seemed to sit on completely tight. Has anyone ever experienced oil blowing out from in between the valve cover and heads?
What would the remedy be for this? Run the catch can from one valve cover to another, and then put a small filter on top of the oil cap using a fitting to hold it in place?
Old Oct 20, 2009 | 09:19 AM
FarmTruc's Avatar
Performance Trucks Sponsor
I know you have the sts and is your oil return line still on the cap?
If so, tap the valve cover and put it there.
Almost every cap that has the return there seems to leak just a bit. It's just not a tight seal or sturdy enough to support a hose.
Old Oct 20, 2009 | 09:49 AM
ducky's Avatar
The return line comes off the valve cover right below where the cap is.
Old Oct 20, 2009 | 11:38 PM
$nake Charmer's Avatar
I ve never seen it " blow" out between the two, but I have experienced blowing my diostick and engine fill cap off under boost on an old motor, motor was hurt
Old Oct 21, 2009 | 11:31 AM
BlownChevy's Avatar
blownerator
25 Year Member
You sir are going to have a new motor in your future.
Old Oct 21, 2009 | 12:06 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
It's possible that your valve cover gasket may not be sealed. Have you ever had the covers off?
Old Oct 21, 2009 | 12:17 PM
Phantom's Avatar
11 Second Club
bet theres a hole in a piston...
Old Oct 21, 2009 | 12:42 PM
Or you might have blown past a ring
Old Oct 21, 2009 | 01:09 PM
ducky's Avatar
I actually believe it might be coming out of the cap itself. The cap has a decent amount of play in it, and never sealed firmly onto the valve cover. I have had the valve covers off, but it never did it before
Old Oct 21, 2009 | 01:13 PM
charcold-bowtie's Avatar
the cap will screw right into the cover, without the filler neck.
