Blower cam with no blower..... yet
Sorry if this is in the wrong place please move it if it is.
My question of the day is what is the difference between a cam rated to be used with a supercharger in comparison to a normal cam not rated for supercharger use? Hypothetically if I was to get a supercharger in the future but would like to cam swap for now would I be able to put a cam that works with the future supercharger in a NA engine?
I also would just like some information on the differences between the two "types" of cams.
Most of my questions that I post on here are for a future build that I am slowly trying to piece together and just have a better understanding on how engines run.
Overlap is the main difference. Medium to large NA cams use overlap to increase cylinder filling in the middle to upper RPM range. The consequence of this is you are not making compression with the valves open and a very small amount of the intake charge can (and probably does) go out the exhaust valve before it's burned. With FI, you don't have a cylinder filling problem, so cams will generally have less overlap than NA cams. FI cams generally don't chop at idle because of the little to no overlap, unless you go big. FI cams generally have good street manners even without FI.
Read post #2. As far as the specific values recommended, the OP was looking for very low range boost. But the concept of what makes a good SC cam still applies. I say "SC" specifically instead of "FI" because what makes a turbo-boost cam is a different matter.
https://www.performancetrucks.net/fo...ow-cam-557149/
I have a supercharger cam in my 5.3, it drives very nicely out of boost. Lots of torque and it's not bad on fuel either. It idles smoothly and still has a slight chop, once the charger takes over that thing lets the 5.3 scream. I would not be afraid to drive around on one without a charger at all...
If you are worried about driving on an FI cam before you have the blower, I wouldn't worry. Of course you could post up which cam you are thinking about and get feedback from someone who may have done the same thing.
Jamesbond2509
Feb 13, 2005 08:17 PM
