Blow off valve/bypass valve location
Old Dec 2, 2005 | 03:01 PM
Kilrfx's Avatar
Default Blow off valve/bypass valve location
On a centrifigal S/C where would the blow off valve go? I am pretty sure it goes between the S/C and TB but not a 100% sure. Any help would be appreciated. Thanks
Brett
Old Dec 2, 2005 | 03:08 PM
black_yukon's Avatar
it should go after the s/c but before the MAF sensor.
Old Dec 3, 2005 | 09:25 AM
Kilrfx's Avatar
So the MAF needs to be moved???
Old Dec 3, 2005 | 01:21 PM
parish8's Avatar
single digit dreamer
it depends on if you are using it as a blow off or a bypass valve.
to me blow off means it just lets the air to atmosphere. if you let it blow off you will want your set up to be. airfilter>blower>bov>maf>tb. that way the maf wont be reading air and fueling for that air that you are letting out to the atmosphere.
if it is a bypass valve that means you are tying the discharge of the bypass back into the pipeing preblower. in that case you can put the maf before the bypass valve tie in in front of the blower or after the bypass valve. typical set up might be airfilter>maf>bypassvalve return line>blower>bypass valve>tb.
Old Dec 3, 2005 | 05:23 PM
TURBHOE's Avatar
right on the money on that one ain'tcha.
Old Dec 4, 2005 | 05:44 PM
blackboostedinfla's Avatar
What type of setup would be the best to use with a procharger.
Texas5.3_1251
Mar 5, 2016 08:10 PM
FlyingLow
Nov 24, 2015 10:05 AM
chopperloco
Sep 28, 2015 08:40 AM
TrickTurbo
Sep 23, 2015 08:41 PM
cousblake11
Sep 9, 2015 06:52 PM
