Bigger Heat Exchanger for 15 up trucks.
Old May 19, 2016 | 08:59 PM
NORCAL TBSS's Avatar
Restricted User
Default Bigger Heat Exchanger for 15 up trucks.
I got the whipple 2.9 in my escalade today and when installing the heat exchanger I could totally put a bigger unit in.
Does anyone make a bigger hx unit for the newer trucks running maggies or whipples?
Old May 19, 2016 | 09:12 PM
TrickTurbo's Avatar
Truck Sponsor
Custom.
Find a radiator from summit that fits.
You'll have the largest hx for your truck.
Old May 19, 2016 | 09:21 PM
PSM's Avatar
PSM
The Eforce hx is pretty darn big to me.
Old May 19, 2016 | 09:29 PM
madmann26's Avatar
Like Rick said, custom. HE's are one of those parts that have the same purpose across many different manufacturers.
Find one that fits, does a better job and adapt it.
Old May 20, 2016 | 08:51 AM
Vortec350ss's Avatar
That bad boy looks huge!
Old May 20, 2016 | 09:50 AM
ZO6Ted's Avatar
Gotta agree, very nice!
Old May 20, 2016 | 10:06 AM
Atomic's Avatar
I have a gauge for that
Just want to point out that the limitation of these systems is usually the intercooler under the blower, not the heat exchanger in front of the grille.
Old May 20, 2016 | 10:26 AM
BLKSSLTT's Avatar
formerly turbo4.8 (2014-06-25)
iv thought about having a custom one made. but it would be like $400+ in materials alone. im curious who has adapted something custom that would show significant gains. Has anyone put any pusher fans on theirs? Only issue I foresee is fitting a 40k up front along with a large HX in a NNBS
Old May 20, 2016 | 10:48 AM
madmann26's Avatar
As Atomic has pointed out, the week link is the intercooler under the blower. A larger HE will greatly help with recovery times. Putting fans on will only help if you drag race but will probably hurt you in everyday driving because of the restricted airflow.
Old May 20, 2016 | 12:52 PM
03sierraslt's Avatar
On my Magnacharger setup that wasn't quite the case. Last season I was getting high IATs ( 80 Degree increase on a 0-130 Pull) So I did a bunch of testing and ended up with a Second HX and now I see a 22-24 Degree increase under the same conditions.
That was at 15psi spinning to 6600 with a 2.9" pulley and a 10% OD Crank pulley FYI.
