better IAT's slowing down coolant pump?
Old Feb 28, 2012 | 12:10 PM
  #21
blwn4.8's Avatar
Im running two hex's and an icebox, as they did in the CHP article.
Old Mar 28, 2012 | 09:01 PM
  #22
snow white's Avatar
I am currently waiting for a 20gpm pump to see if it helps, I also am running 2 hxr and will log iats before and after. Pump should be here monday.
Old Apr 2, 2012 | 09:18 PM
  #23
blwn4.8's Avatar
any results on this??
Old Apr 2, 2012 | 11:35 PM
  #24
WHPLSH's Avatar
Get it on a dyno and get a temp gun. do a pull without methanol and one with. take notes on the exhaust temps before both runs and after. from my experience with roots style blowers is the iat sensor its self gets heat soaked while sitting in the alum manifold. the iat's that it reads after a run or a long drive arent necessarily what the engine sees in the cylinder. after a pull with meth the exhaust temp dropped over 150* but the iat's stayed the same. the temp dropped even stayed after adding 2* and an upper pulley swap. iat sensors that are placed in alum tend to give a false reading of the actual temp the cylinders see.
Old Apr 2, 2012 | 11:45 PM
  #25
TX Tahoe Z71's Avatar
Originally Posted by ayousef
if your heat exchanger is too small, a slower flowing pump might be more beneficial. Im stepping up to a meziere 20gpm pump vs the current 6gpm however I am also getting a custom heat exchanger that is at LEAST twice as thick and a few inches wider, should work nicely.
I have had the meziere wp136 pump under my bed for over 2 years and have been meaning to install it this entire time. I have actually done headers, cam, bigger injectors, full stereo and e85 tune since I bought it. Please post up results because the wait has been killing me!
Old Apr 4, 2012 | 05:04 PM
  #26
loloone's Avatar
LS1Tech Editor
Sorry to clutter the thread but, subscribing!
Old Apr 7, 2012 | 11:19 PM
  #27
snow white's Avatar
Ok I got the pump put in and on a 50 deg f day iats peaked at 125 after a wot pull to 110mph. Before the pump change they hit 136 and climbed very fast. They seem to take a little longer to climb up and peak is lower so I would say its worth the swap.
Old Apr 8, 2012 | 02:55 PM
  #28
Awesome! What pump are you running and where did you mount it? Is it noisy? Pics?
Old Apr 8, 2012 | 03:56 PM
  #29
snow white's Avatar
I am running the meziere 20gpm and mounted it in the drivers wheel well along the frame. I will post up some pics when i get a chance
Old Apr 8, 2012 | 04:11 PM
  #30
Great, thanks! Is it noisy at all from in the cab?
