Best turbo kit these days
Old Jun 28, 2022 | 09:42 PM
slowlowtaco's Avatar
Registered User
Default Best turbo kit these days
I’m new to the site been lurking and searching for a bit. What’s good brand turbo kits and turbo sizing these days? I’ve got a 69 C10 with a 99 5.3/4L80 running terminator max. Been breaking in the motor/trans for about 300 miles and am fixing the last couple kinks. Motor has Summit turbo cam, ls7 lifters, trunion bearing upgrade, new valve springs, gapped .027 rings, mls gaskets and ARP head studs. Goals are low to mid 600’s wheel. Been looking at kits and have no real idea which ones are the go to kits. My buddy suggested Trick. Also wondering what turbo and injector size I should run. Currently have stock truck manifold but am likely going to swap over to the Holley high ram with 102 TB as I like how it looks.
my tuner suggested going with a Works brand turbo as he has used a bunch and has been pleased with them.
I’d love to hear some opinions on what I should look at.
Old Jun 28, 2022 | 09:46 PM
shakenfake's Avatar
Shlumpt
5 Year Member
Trick is good
Turbo size depends on your drivability goals. I would do a Borg Warner turbo but that's just me.
Injectors must be beef, think 70 lb/hr
Old Jun 28, 2022 | 09:49 PM
Registered User
Originally Posted by shakenfake
Trick is good
It’s just a weekend cruiser. Some freeway pulls but no drag racing. I want it to be fun but I’m not going to be hot rodding from light to light.
Old Jun 29, 2022 | 10:36 PM
Atomic's Avatar
I have a gauge for that
Work turbo is good, they arent far from me. Reed makes a nice unit, the 82mm he did for me performed well.
Old Jun 30, 2022 | 02:43 AM
RDF1's Avatar
DuNnO
5 Year Member
If you can find a used KB Racing turbo kit you would be in luck. RIP Kyle...
I've had very good luck with Huron Speed. I prefer borg Warner turbos since I've never had a failure out of them on mine or any of my customers vehicles. But the Hurons seem to be doing very good so far.
Old Mar 2, 2023 | 02:56 PM
Turbo 6.0's Avatar
I just finished up a C10 using one of my 99-13 GM truck hot side kits. I ended up having to build a custom downpipe but the manifolds, crossover pipe and T4 Y-pipe fit great!
Old Mar 2, 2023 | 03:14 PM
arthursc2's Avatar
How does that clear the PS pump?
Old Mar 2, 2023 | 03:22 PM
Turbo 6.0's Avatar
It has over an 1" of clearance. Haven't had any heat management problems yet!
Old Mar 2, 2023 | 03:31 PM
arthursc2's Avatar
Perfect! Metal reservoir ftw
Old Mar 2, 2023 | 03:35 PM
Turbo 6.0's Avatar
I also apply some gold reflective tape to the reservoir for added protection.
z13976
Jul 10, 2012 11:52 AM
Hemitruck04
Dec 18, 2010 08:46 PM
btlfedbu
Aug 27, 2009 04:43 PM
wastedrubber
Mar 10, 2008 09:34 AM
j4nash
Oct 15, 2003 12:29 AM
