best square port head for boost
Old Apr 10, 2019 | 06:48 AM
  #21
vettelovralexand's Avatar
stock bottoms for life. this motor would be a 6.0 or 6.2 if i originally built it. the 408 came with Annebelle (yes i named my cursed car after the cursed doll).
i'm not sure my OCD will let me slap it back togehter...It's probably comming out for 1 new piston. i'll re-use the rings from that hole to avoid honing.
I am the same way. It would be way cheaper to clean it up and send it, but I'd always know it was there.
Old Apr 10, 2019 | 11:11 AM
  #22
1FastBrick's Avatar
Custm2500's Rude Friend
Talking
Sound's you like you need to have a talk with your OCD...
I had to fight my OCD on the junkyard special. I Literally pulled the best 2 pistons and rods out of a pile from another junk motor to repair that motor. They still were not as nice as the stuff in this motor. If the lube holes were not blocked on 2 of the cam bearings and I didnt see some lube issues on the original cam, I would have put them in and sent it. But I did re-use the bearings and rings as there was nothing wrong with them...
Also I stayed at a Holiday Inn...
Old Jul 29, 2019 | 04:42 PM
  #23
TXsilverado's Avatar
I ended up with texas speed PRC as-cast 257cc heads with the upgraded valves and dual .660 springs. I looked hard, and you cannot beat the bang for buck factor of these heads. 6 bolt, thicker deck and better valve angles. Best of all,Texas Speed had the heads, head gaskets and a few other odds/ends to my loading dock in 1 business day!
Old Jul 29, 2019 | 04:47 PM
  #24
arthursc2's Avatar
must be nice living in Tejas haha
Old Jul 29, 2019 | 09:28 PM
  #25
montecarloss's Avatar
LS ADDICT/BUILDER
Sounds like race car parts
JordanH
Dec 23, 2015 10:43 AM
Lucille
Sep 10, 2015 08:29 PM
xx_ED_xx
Sep 10, 2014 04:31 AM
xx_ED_xx
Jul 29, 2011 11:19 AM
