Best heads for fi?
Old Nov 14, 2010 | 11:42 PM
miller white's Avatar
Default Best heads for fi?
Heard some mixed reviews about the l92 heads. Just wondering what some of you are running. Going to be running these on a 6.0. Thanks
Old Nov 15, 2010 | 02:51 PM
teamblackandred's Avatar
what are u running for a blower?
Old Nov 15, 2010 | 02:55 PM
Daryn's Avatar
Formerly darynC-10/23/10
some 317's would do you just fine
Old Nov 15, 2010 | 06:16 PM
old motorhead's Avatar
You can't beat the L92/LS3 heads for mild boost in a stock configuration. Even ported 317's or 243's usually fall short of stock LS3's. One of the best bang for the buck heads out there. They may not be the best for a high boost all out rig, but they will do just fine with mild boost.
Old Nov 15, 2010 | 06:25 PM
dbtbss's Avatar
L92's get a bad rep... I run 24# boost and 18* of timing on my 403 w/ twin76's with no issues. No meth, no N20 for cooling... just a big I/C
Old Nov 15, 2010 | 06:32 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Depends on what type of FI you are going!
Old Nov 15, 2010 | 06:56 PM
Please expound
Old Nov 15, 2010 | 06:58 PM
2.2 kenne bell.
Old Nov 15, 2010 | 07:46 PM
dbtbss's Avatar
Doesn't matter what kind of FI as long as x, y, and z are taken care of... coolant system/temps, oil temp/pressure, timing, maintaining crankcase pressure, iats, fuel system, fuel used, etc. etc.
Old Nov 15, 2010 | 08:23 PM
trever1t's Avatar
Well I was referring to compression where some forms of FI benefit with more or less than others. 317's on a 5.3 would suck in my opinion. He might benefit with 243's milled down to bring CR up to 9.5-10:1 with the KB blower, no?
