Best buys on MagnaCharger
Old May 24, 2006 | 09:48 AM
  #21
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by mjhoward
Good old free USA at work here boys! If you can't stand the heat get out of the kitchen! Amen.
i like the fire
Old May 24, 2006 | 05:27 PM
  #22
Scott Mills's Avatar
I was towing between 3k and 5k and my EGT guage goes to 1600, my readings were off of the scale.
Old May 24, 2006 | 05:54 PM
  #23
old motorhead's Avatar
1600+ sounds pretty ugly. Was this a stock set up, or were you pushing things a bit? What kind of boost pressures were you running at those temps? Flat roads or hills? Sorry for so many Q's. Appreciate your taking the time to answer them.
Old May 24, 2006 | 06:17 PM
  #24
I was running 7 Psi with an intercooler, flat roads.
Old May 24, 2006 | 09:04 PM
  #25
BlownChevy's Avatar
blownerator
25 Year Member
if you are using that truck for mostly towing, I would HIGHLY suggest a larger pulley and a "towing" calibration from magnuson. I had a 2003 2500 HD that towed a 34 foot enclosed car hauler (18.5K total weight) 50+K miles during the summer accross the US, and never even saw a HINT of a issue.
Old May 25, 2006 | 08:05 AM
  #26
m7 rocket's Avatar
Does anyone know what the stock pulley size is on my application and what the "towing" pulley size should be? Does the stock belt still work?
Old May 25, 2006 | 08:24 AM
  #27
BlownChevy's Avatar
blownerator
25 Year Member
should have a 3.2 on there now, I would run a 3.3 or even a 3.4 on it to tow. yes the belt will be fine.
Old May 26, 2006 | 07:21 AM
  #28
m7 rocket's Avatar
And you measure the outside of the ribs on the pulley, towards the middle of the pulley not including the front and rear outside edges? Right or wrong? My dealer must have changed pulley because the alignment is not 100% from front to rear and there is no stamped info on pulley.
madmann26
Apr 29, 2020 09:17 AM
Avalanche2002
Nov 30, 2015 07:31 AM
OHsixLS3
Nov 22, 2015 07:45 PM
nabozny21
Oct 17, 2015 07:47 PM
