Belts
Old Sep 21, 2005 | 08:40 PM
03sierraslt's Avatar
Default Belts
Just curious if anyone that has used goodyear gatorbacks has noticed a slight whine from the belt at any rpm. I am getting a slight whine from my gatorback at idle and part throttle, naturally I cant tell if i am getting it at wo, truck is too damn loud. At least I hope it is coming from the belt, This is why I am asking. Was thinking of throwing the gates back on just too see. I figured with the gatorback having the diagonal lines cut across the ribs maybe it might make a different noise.
Old Sep 22, 2005 | 02:38 AM
thunder550's Avatar
High on diesel fumes
I picked up a slight whine too when I switched to the Gatorback...it didn't occur to me that it might be the belt. I will have to experiment with it a little and see if that's really what it is.
Old Sep 22, 2005 | 02:27 PM
well i will let you know here in a little bit, I am going to switch to a gates that i have too see.
Old Sep 22, 2005 | 03:00 PM
krambo's Avatar
I only use the gatorback. I switched from the dayco and really didn't notice a difference in the whine. Over the exhaust, it is hard to tell anyway.
Old Sep 22, 2005 | 03:15 PM
Ok, I put the gates on and NO whine. So Now that I know it is just the belt i put the gatorback back on. Personally I think it sounds sweet. The whine is coming from where the belt wraps around the blower pulley that is why i was concerned, however all is good. I dont like the gates becuase I can not keep them from slipping when it shifts, however with the same size gatorback it does not slip. It was embarassing, I would pull out of a car cruise or something and when it would shift the belt would screech. It sounded like there was a cat under my hood.
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Tigger Welder
Oct 1, 2015 08:41 AM
murderedSS
Sep 27, 2015 10:16 PM
97_ek
Sep 23, 2015 09:16 PM
hackrst
Sep 2, 2015 05:27 PM
