Belt slip or rich spike? HPT log inside.
Old Feb 26, 2011 | 05:14 PM
CashDudeHomie's Avatar
Default Belt slip or rich spike? HPT log inside.
Guys, I'm still getting a hesitation during very rapid throttle transitions. When gradually getting on it, everything is perfectly smooth. I have a little bit of belt slip, but I think this might be a rich spike. If so, how do I tune this?
Look around frame 2281.
I'm still learning the ways of HPTuners. Thanks for looking.
File Type: hpl
Old Feb 26, 2011 | 05:29 PM
03sierraslt's Avatar
do you have any logs where it does this and you stay in the throttle so we can see what it is doing the whole way through? What is your enrichment rate set too? What are your PE enable parameters?
Old Feb 26, 2011 | 07:31 PM
terravast4's Avatar
I have this also....does it downshift into boost...hesitate rev again then continue into boost?
Old Feb 26, 2011 | 08:31 PM
Yes it does. I will get some better logs next time. It doesn't always happen, but it scares me so I usually let off. Enrichment is 1.29 and
enable is
Map 85
Map Hyst 6
Delay RPM 100
I've never messed with those settings. Are those about right?
Vortec350ss
Jan 12, 2016 10:36 PM
Gadgetized
Oct 22, 2015 09:06 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Chevy305
Sep 28, 2015 09:21 PM
murderedSS
Sep 27, 2015 10:16 PM
