Bed mount turbo Help please!!!!! LQ4 GT4502
Old May 14, 2015 | 08:17 PM
mudhippy's Avatar
Talking Bed mount turbo Help please!!!!! LQ4 GT4502
I got a stock 03 2500 hd 4x4. Wanting to do a bed mount to keep things simple under the hood. First question is am i going to lose a lot of horse power by not running an intercooler like i would if it was under the hood? The truck will get one plumbed in later. Second is what should i do with the exhaust to feed the hotside? It has the stock manifolds with dual 3in exhaust and the turbo is a twin scroll? Thanks for the input.
turbo specs Gt4502. Divided housing.
Compressor:
.66 a/r ratio
69.5mm inducer
102mm exducer
Turbin:
1.33 a/r ratio
88mm inducer
90mm exducer
Old May 16, 2015 | 02:09 PM
GRRR65GTO's Avatar
Id say the compressor is a little small to feed a 6.0. The twin scroll part doesnt matter much with our V8s, all the exhaust is gonna go through a single turbo. So the easiest thing would be to merge the exhaust into one then into the flange, and you dont need to do a bed mount, you can do it under the bed like STS which has been around for a while. People do run rear mount with out an intercooler but its really not that hard to put an intercooler in and they are not the expensive.
greedygenius
Sep 3, 2015 06:51 AM
Wareagle23
Aug 8, 2015 10:06 AM
Jake99
Aug 8, 2015 07:56 AM
71ls2
Jul 20, 2015 11:53 PM
