BD Diesel Turbine Diverter Valve
I remember somebody not too long ago made a thread about building one of these themselves
BD Power - Product: TDV Turbine Diverter Valve
I wonder if the spring could be adjusted or swapped out so it could work for us
It comes in a T4 mount, the only issue is the down pipe would be pretty far off now on a log manifold
It's the same thing as a quick spool setup, the difference being that cummins use a divided manifold, so there must be an open area to have both sides diverted to one volute on the turbine. That's why these are so thick. If not you would be trying to block off half the cylinders, not half the housing.
