Back to the other dark side...TVS2300 here I come!
Old Apr 15, 2009 | 10:49 AM
  #101
fastlt1's Avatar
12 Second Club
Not to ask a dumb question but where are you guys getting these tvs2300s. I can't find hardly anything on their website about it.
Old Apr 15, 2009 | 10:53 AM
  #102
kbracing96's Avatar
Originally Posted by s/c'd cav
here is the thing the rails are aluminum , put a plug in the end of the rail , and then drill and tap the bottom of the rail , or just leave it capped off
the fuel will come in the other side , and i know the adj fpr chris has has the return line out of it
that's what I would do, just plug the end and put the fitting on the bottom of the rail
Old Apr 15, 2009 | 11:47 AM
  #103
thunder550's Avatar
High on diesel fumes
What about this? Any reason why I couldn't plug the end of the fuel rail and run it like this? My current setup is on top, and possible new setup on the bottom.
Old Apr 15, 2009 | 11:49 AM
  #104
thunder550's Avatar
Call...you can call Magnuson direct, but leftcoast32 is a sponsor and a distributor, might be better going through him http://www.leftcoast32.com/
Old Apr 15, 2009 | 11:58 AM
  #105
thunder550's Avatar
More pics I stole from grippy...if this fuel rail were blocked off flush, or not even drilled/tapped on this end, looks like it might clear? Will have to call Brian to double-check.
Old Apr 15, 2009 | 12:03 PM
  #106
s/c'd cav's Avatar
or even welded up , and shave some off the end if necessary
Old Apr 15, 2009 | 12:27 PM
  #107
Wilde Racing's Avatar
How do I change this text
Looks like a bango fitting might clear. Far from ideal though
Old Apr 15, 2009 | 02:33 PM
  #108
vanillagorilla's Avatar
Damn if 60's is all you can go with, that really sucks. You could still compensate with meth, but that's a band aid IMO. I guess you could up the FP a bunch with a big *** pump(s) and/or a voltage booster, but that's not going to get you much. Just ditch the rail and get a custom one made.
It's going to be interesting to see all the things that are needed to make this setup work.
Old Apr 22, 2009 | 06:08 PM
  #109
thunder550's Avatar
This is a nice looking piece! Much cheaper than most of the other 90mm throttle bodies out there, and it comes with new IAC and TPS Thanks to Richard @ WCCH!
Headers will be here Friday.
Old Apr 22, 2009 | 06:34 PM
  #110
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Richard has and knows of all kinds of goodies, I think thats the TB he told me about almost a year ago
