Anyone run an engine oil cooler with turbos?
Old Apr 6, 2014 | 03:30 PM
TURBHOE's Avatar
Originally Posted by Atomic
I do...with it the temps usually stay in the 190-210 range. Without it my gauge was maxed out at 250 in about ten minutes of easy driving. It makes me feel better and the oil last longer, but look at how many guys dont use one and dont have problems....
Are you running just the stock one in the radiator? the cooler lines came on my 6L and was thinking about getting the radiator that has the engine oil cooler in it.
Old Apr 6, 2014 | 04:24 PM
Atomic's Avatar
I have a gauge for that
No I use a generic b&m one.
Old Apr 6, 2014 | 05:09 PM
TURBHOE's Avatar
Ok. I wonder how good the stock one does. I'll keep searching lol
Old Apr 6, 2014 | 10:14 PM
GRRR65GTO's Avatar
I was gonna say, are we talking about no cooler at all vs an external or vs a factory radiator one?
My truck being a 2500HD i have the radiator one so im assuming i shouldnt have to worry...
Old Apr 7, 2014 | 05:24 PM
cpolaris502's Avatar
I'm planning on getting this cooler adapter pretty soon to run to an external cooler.
http://www.improvedracing.com/cooler...80f-p-209.html
It has a built in thermostat to allow the oil to get to 180 and stay there, rather than continuously flowing through a cooler which can keep it too cold on the highway or winter. I'll be doing a few days of road coarse "cruising" as they call it at Powercruise each year and things heat up fast when you're beating on it on a race track. Also, just another thing to make my engine last that much longer... as long as the fittings and lines don't fail!
Old Apr 7, 2014 | 09:22 PM
Choda's Avatar
Neat little piece. Do you guys use a cooler w -4 or 1/4 fittings or use reducing bushings.
Old Apr 7, 2014 | 09:32 PM
Atomic's Avatar
-8an to 1/2npt
Old Apr 7, 2014 | 09:33 PM
stroker87's Avatar
I was thinking of adding one to my truck when I do the turbo was also wondering if a high pressure/high volume pump would be better since my turbo is going to be rear mount?
was looking at the melling 10296 pump
Old Apr 7, 2014 | 10:41 PM
RS/SS 4.8's Avatar
10 Second Truck Club
What about from the engine to the cooler to the turbo back to engine? Probobly not enough flow going from -8 to -4 and then through the turbo huh?
Old Apr 8, 2014 | 05:38 PM
GRRR65GTO's Avatar
You could T it, have go back to the engine and the turbo
