Anyone know if these pulley's will work?
Just curious if these will work with the whipple that's on my truck? Edit: and does anyone know what size is stock on my model?
NON SPONSOR LINK
NON SPONSOR LINK
NON SPONSOR LINK
NON SPONSOR LINK
Yeah, I used the calipers and could see it was close to 4". Didn't know what part they measure from though to get the the size. Just wondering why it's so difficult to find pulleys for our setup.
Originally Posted by 91_bowtie
Whipple is the only source that I've found. What size are you looking for? I'll be getting rid of my 4" pulley in the next month or so. 12 psi here I come.
Yes - Whipple is the only place I have found them also.
For every change in diameter of 1/8 inch- it changes 1 lb of boost.
Stock should have been 4 3/8 or 6 psi on a 2300 axo unit
So a 4 inch will make 7.5 psi
I have if needed...
4 3/8-6psi
4 1/4 -6.5psi
3 7/8-8.0psi
Hope this helps
I have if needed...
4 3/8-6psi
4 1/4 -6.5psi
3 7/8-8.0psi
Hope this helps
I have if needed...
4 3/8-6psi
4 1/4 -6.5psi
3 7/8-8.0psi
Hope this helps
I have if needed...
4 3/8-6psi
4 1/4 -6.5psi
3 7/8-8.0psi
Hope this helps
If you don't mind me asking... What did whipple charge you for the pulleys? When did you purchase them? I've seen a range of $60-140 for each pulley. I was the 140.
Ideally yes; but the cam, exhaust, etc. will make the numbers sway a little. This is being discussed more in the thread about adding headers in this section.
