Anyone have a MP90 Rotor pack lying around???
Old Jun 2, 2012 | 12:17 AM
1SloLQ9's Avatar
Default Anyone have a MP90 Rotor pack lying around???
Hey guys, put a mp90 on my truck and the rotor bearings are starting to wear causing knocking in the charger, looking to see if anyone has a rotor pack lying around out of that setup thats good or know a good place to just rebuild the rotor bearings? I called embree they want 595 to rebuild unit minimum cost and i've already replaced snout bearing and seal and rear needle bearings. so just trying to find a rotor pack and replace mine.
If you have one please pm me.
Old Jun 2, 2012 | 01:43 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
What kind of cam are you running in the engine? Sometimes a choppy cam will make the blower knock just because of the crankshaft speed variation at idle. Can you post a vid?
Old Jun 2, 2012 | 09:04 AM
1SloLQ9's Avatar
I'm running an ls1 cam out of a lq4, Put it in because it was basically free from a friend and we did it in about 4 hours. Its not just noisy at idle, its noise through the entire rpm band, It has a different tone in its whine, I had a ported m90 in my gtp and I know what they should sound like. This sounds more like a dental drill when its whining out vs a whistle.
Sounds like rocks grumbling around all the time. Coupler is good, snout bearing is new as well as rear needle bearings.
as for a video i'm not sure I can post one of those on here since i have not been a member for very long.
Old Jun 2, 2012 | 09:36 AM
TIM Z's Avatar
11 sec. Truck Mod
Craigslist or fleabay is your friend bro, hell there is a ported M90 in ohio on canton CL for 150$.
I'd like to see pics too!
Old Jun 2, 2012 | 09:44 AM
03sierraslt's Avatar
You should be able to post a video, you will just have to host it somewhere like photobucket.
Old Jun 2, 2012 | 11:15 AM
What kit is it?
Old Jun 2, 2012 | 11:36 AM
89LS1FOXER's Avatar
DO NOT use Embree, had some huge issue's with him rebuilding my old side mount mp90
Old Jun 2, 2012 | 11:43 AM
89LS1FOXER's Avatar
You might call magnacharger too, a while back they were blowing out 4th Gen MP90 blower units for like 300 bucks on ebay, brand new never used, just had to swap my nose over and i was good to go, see if they have one hiding somewhere??
Old Jun 2, 2012 | 01:25 PM
1SloLQ9's Avatar
Alright I will call up magnacharger and ask if they have any units lying around. Does anyone know if blownchevy still works there? as for using a m90 It needs to be a gen v rotor pack. I have newer style rotor pack.
Old Jun 2, 2012 | 01:49 PM
Blownchevy no longer works at Magnacharger.
Wolftrk99
Dec 3, 2015 08:12 PM
OHsixLS3
Nov 21, 2015 10:41 AM
dsbodley
Nov 14, 2015 09:46 PM
The_W
Oct 1, 2015 02:35 PM
