Anybody using single fuel pump in Silverado with e85?
Just curious if anybody is using a large single fuel pump setup on their Silverado with e85 making around 750-800. It seems like most people are running dual pumps at this power level. I would like to maybe use a Magnafuel single pump or something with e85 but just wanted to get some opinions. Thanks.
I would think you would need something like a A1000 with controller or maybe one of Holley's 2 in 1 Dominater pumps for that kinda fuel. Don't think a wb450 is gonna get you there.
I run a single aem 380 on my street nova on e85. 6.0 ,s480,glide,3.23 gears. I don't know the hp but it runs 10 teens at 135 mph at 3600 lbs on 12 psi boost. it is not out of pump yet . still holds solid afr down track.
-6 feed to stock truck intake/rails at 54 psi static. 5 1/6 return.
I'm using a single Walbro 450 part #F90000267 and a Kenne Bell 20V BAP and E85 and made 650/627. This is where the pump was maxed... dropped 1psi @ 14lbs and 2psi @ 15lbs. When I get time this week I'll be putting in the F90000274 in place of the 267. I like the simplicity of the BAP and single pump.
d_gans96
May 3, 2016 10:11 PM
lxcoupe
Apr 11, 2016 05:47 PM
