Anybody slipping the belt on there centri setup????
#21
I had a problem with belt slip and throwing the belt as well. I run 15 psi with a 3" pulley on my Paxton 1500. To help from throwing the 7 rib belt, I fabbed up a bracket and used a screen door turnbuckle to keep the stock tensioner tight at all times. I added a through bolt through the tensioner pulley and attached one end of the turnbuckle to the through bolt and the other end to the fabbed up bracket. Then I just tighten the turnbuckle. As far as belt slip, you guy's can laugh if you want, but I put VHT on the rib side of the belt. I carry 2 spare VHT prepped belts with me when I go to the track plus the one on the truck. I prepped them and then store them in a Ziplock plastic bag. I can get around 10-12 passes before I see any loss in boost so I rotate them out after every 6 passes or so just to be safe. Don't apply VHT to the belt when it's on the truck. It makes a total mess in the engine compartment. This may sound like a backwoods fix, but it works for me.
#22
Thanks for the info guys.. I think I am going to do what a fellow member here done in the past. I am going to move the pulleys around to get more of a bite on the pulley.. Then if that doesn't work, I am going to snag the tensioner from maggie...
John
John
#24
#25
or they could have just done it right the first time vs. rushing them out.
#26
#27
#28
https://www.performancetrucks.net/fo...d.php?t=429718
John
SlvrSierra4.8
Oct 1, 2015 09:39 PM
iregret
Sep 7, 2015 01:20 PM
