another wg vent to atmosphere topic
Old Apr 29, 2006 | 06:02 AM
hemifever's Avatar
Originally Posted by TurboBerserker
I had that problem at first, but it was the result of having too big a vacuum line between the boost controller and the WG. The only other thing I could think of that may cause that is having the controller plumbed incorrectly.
Can you lock up your converter Hemi? If so, you can build boost like a madman with light throttles.
I'm using 1/4" hose. I've emailed drawings and pictures of my EBC to WG plumbing to STS a few times and all is well on that. I have 4.56 gears and a 2600rpm stall converter. The converter has a 2.52 tq multiplier (stator) which really puts down the power off the line. I've got a handscanner that monitors everything on the truck. I might see 1 or 2 degree's timing being pulled out via the pcm.
I installed a Blitz Spec S EBC two weeks ago and got worse results than with the STS EBC.
I think I can put a switch in to lock up my converter but I've never gone about getting the wire diagram for that.
Old Apr 29, 2006 | 06:05 AM
hemifever's Avatar
Putfile is working now. Here is the video. This is a 90mph run. Truck weighs 6000# with me in it. If you keep pausing and starting it you'll see the boost #'s exactly and how they go up and drop.
http://media.putfile.com/Boost-drop
Old Apr 29, 2006 | 06:06 AM
hemifever's Avatar
The Cuda sounds like fun! What color?
Old Apr 29, 2006 | 10:04 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Truck sounds nice!
Those are the exact symptoms I had.
Forgive me here -- I've got a head cold and can't think straight this a.m. -- Doesn't the kit come with 1/8 vac lines?
I AM A MOTHERF*CKER
Love it!
Old Apr 29, 2006 | 10:37 AM
hemifever's Avatar
Truck sounds nice!
I believe 1/4" is what came with it, least with my kit. I just test drove it with the wg vented to atmosphere and there wasn't a change. ugh. I was hoping that was it.
I just keep wondering if my turbo has enough umph to keep those pipes filled.
Old Apr 29, 2006 | 12:18 PM
hemidup's Avatar
Can you get a larger turbo for your STS setup? After watching the video, I'm starting to think what your thinking.
Old Apr 29, 2006 | 12:24 PM
ktmrider's Avatar
What is the A/R size for the hot/exhaust side on the GM kit? The Dodge is 0.96!!!! I wonder if this is why we were having so much trouble building boost in lower gears as the hp/trq values start falling at higher RPM's?
Old Apr 29, 2006 | 01:37 PM
I AM A MOTHERF*CKER
My GT67 was a 0.96 as well.
What size turbo do you guys get? A 67? Do all you guys have trouble with the boost dropping off?
I'm starting to think I had trouble with a 3/8 line, but its been about 18 months lol.
Hemi have you had the WG apart to change springs or anything?
Old Apr 29, 2006 | 01:45 PM
hemifever's Avatar
Our base turbo is a T60-1 with a 67 upgrade. I have the T60-1 with a .96 a/r. Almost all of the hemi folks (excluding maybe 1) have had issues with boost in general. The only one I know that has constant solid boost has a Tec 3r standalone system. Comes back around to tq management playing a role???
