Another Radix question....
Old Jun 3, 2009 | 01:26 PM
  #31
fastnblu's Avatar
Originally Posted by slowfive0
Don't get me wrong...mid 12's is fast and probably plenty (for a month or two--lol)...it felt a lot faster this past winter then when I went 13.10, but I REALLY HATE the dramatic decrease in performance after driving it. Any tips on the tune? Or cam recommendation---right now I have the GT2/3,...
Mid 12's in a vehicle, let alone a truck is quick. Cooler weather is always better for ETs. Ya, heat soak is something ya deal w/, esp FI. I keep seeing Radix kicked for this. That's 1 reason guys are diggin the TVS. Where do u live or run at? The weather is what it is.
Originally Posted by krambo
If you hit great weather (colder the better)...
FWIW, I saw .6 time difference between 85* and 40* ambient temps. A small pulley does not like to start with high ambient temps. IAT's make a huge difference. All of my 11 sec passes started with IAT's lower than 90*...most in the low 80's. Heat soak was an issue for my times.
What a difference!
...Something to do with blower creating how much airflow the engine can have and that it is getting a little small for the 6l motor...
I'm tired of seeing this. The 112 is a nice unit. Now that there's a new sheriff in town, it's getting kicked. Dig up some coin for a TVS.
Dewey said it, parts are gonna fly at some time. Most guys aren't running high 11's, so that says it ain't easy. Nice weather, meth & homework will be a helpful, fo sho. Weight reduction too. Good Luck.
Old Jun 3, 2009 | 01:29 PM
  #32
fastnblu's Avatar
Are you spraying meth through the blower? I thought that was a no no? ...
IIRC, it voids Magnacharger warr.
Old Jun 3, 2009 | 01:48 PM
  #33
slowfive0's Avatar
I completely agree, but I do love speed ;-) Looking at my tune, I can see why I was getting such dramatic change----My tune is pulling 5-9 degrees of timing unless I let it cool waaayyyyy down. I can change that---lol. I'm in the detroit area.
You're missing my point here. I do think the M112 is a great blower---obviously not as efficient as the TVS, but great nonetheless. WHere I was going with it, was I'm doing another motor and I wanted to throw some Dart 225's on there with a better cam. The feedback I see on this topic from old threads is that I will see minimal results. I "believe" the reasoning is because the blower becomes a restriction at some point so any improvements you do to the rest of the system (heads, cam, exhaust, more cubes, etc) are lost are the improvements are minimal....
__________________
04 Silvy RCSB 5.3 Dynatech Full LT System, Corsa Touring, Vararam King Cobra, Hotchkis TVS 2/4 drop, local tune...still learning HPTuners so I can give it a try.
Home of the WINGS! Winning Back to Back Cups. We can't do any worse than 2nd.
Old Jun 3, 2009 | 01:57 PM
  #34
KySilverado's Avatar
I agree about 21* appears to be the sweet spot for timing. Thinking it would be different with an LQ9. I've never played with timing on the dyno just played at the track.
Another thing to look for in the truck tunes at track time is the Knock Learn factor. I still keep a different High and Low octane tables and have had KL kick my timing down on track runs.
Old Jun 3, 2009 | 02:18 PM
  #35
slowfive0's Avatar
So anyone else running 21 with an LQ9?
What's the difference between the high and low octane tables. Is that basically where if you get a predetermined amount of knock it switches to the low octane table. Basically simulating if you got a bad tank of fuel on a stock vehicle??? Is that correct?
Old Jun 3, 2009 | 02:55 PM
  #36
Yes the Hi/Lo Octane timing tables are for timing adjustments based upon how much knock you get while cruising around. It uses knock learn for that. A bias between the 2 tables. A knock learn value of 1 will use 100% Hi table for timing a KL value of 0 will use 100% of low octane table. A bias if anywhere in between.
While driving any instance of KR will lower the KL value. Any LONG cruises with no instance of Knock will raise the KL value.
Old Jun 3, 2009 | 02:57 PM
  #37
slowfive0's Avatar
Awesome---thanks for the info (detail). Nice truck---I can't imagine how many "unsuspecting" people have had it handed to them...lol!
Old Jun 3, 2009 | 03:03 PM
  #38
Thanks. Yes there have been a few hand outs.
Old Jun 3, 2009 | 06:08 PM
  #39
Last Call's Avatar
TOTM: January 2007
Are you spraying meth through the blower? I thought that was a no no? Also, are you using one or two nozzles? Thanks again.
All of us radix guys are spraying threw the blower.. The issue with meth through the blower had more to do with the coating on the Ford Lightning blowers.
I am spraying out of one 15ml nozzle that came with the kit. Controller is set at 5.
Old Jun 3, 2009 | 06:19 PM
  #40
slowfive0's Avatar
What kind of fuel system? I have an 04 with the dreaded returnless system (with a Walbro intank pump). I just installed a magnavolt so I want to start adding some timing now and see if I still have pressure drop. Before it was dropping down to 50 (from 62) at the top of 2nd gear. Hopefully, it is fixed for now.
I'm hoping the meth will offset the handicapped fuel system......
