Another Pro Charger Question
Old Sep 6, 2008 | 06:47 PM
03ssilverado's Avatar
From: On a one way dead end street... And I can't get out
Default Another Pro Charger Question
Ok I have a 2003 SS Silverado. Going to put in a shift kit and trans stuff. What type of TC should I go with. It is my DD. Also what size injectors.
Also read people saying not to use the FMU. Why. Just want to know why you don't use it, or do you go with a bigger one.. All and any info would be helpful.. thanks
Old Sep 6, 2008 | 06:55 PM
coldkillinTA's Avatar
Depending on the boost i'd go with 42#ers. The FMU is alot more basic than injectors and a tune and more people like to get their truck as efficient as possible so a tune is key. good luck!
Old Sep 6, 2008 | 07:03 PM
so if I get a tune (which I am), I don't have to use the FMU????
Old Sep 6, 2008 | 07:14 PM
kbracing96's Avatar
Most guys seem to like about a 3000 stall with the Procharger.
An FMU is sort of a bandaid kind of way to add fuel with stock injectors when you add boost. It raises fuel pressure about 12 psi for every pound of boost, so the injectors squirt more fuel for the same amount of open time.
Going with larger, say 43lbs/hr injectors and a tune for them, is much less stress on the fuel pump and a lot easy to dial the tune in and more reliable.
Old Sep 7, 2008 | 09:19 AM
WJ MARK's Avatar
The FMU will work, but most on here will tell you to get a tune and injectors. On the stall, Do you tow much?? If not I would go with 3k -3500 stall and a larger tranny cooler.
Old Sep 7, 2008 | 12:33 PM
Mangled03gmc's Avatar
Baltimore Whore
Ditch the FMU, go with a tune, injectors, you will be alot happier... Like stated I would rec a 3-3200 converter...
John
Old Sep 8, 2008 | 12:33 AM
11 Second Truck Club
go with a 3000-3200 stall and a multi disc one that should put u right in the power band
bgray
Aug 29, 2015 11:27 PM
hotyamaha36
Aug 25, 2015 10:32 PM
Steve Sr.
Aug 24, 2015 06:31 PM
FlowmasterMufflers
Aug 17, 2015 04:44 PM
USMCvet0311
Aug 1, 2015 07:45 AM
