Another mod'ed TVS2300
Old Feb 9, 2012 | 05:42 PM
  #31
Lucille's Avatar
Seems to work great. A few little issues with the spray bars access on the drivers side but that was expected since the spacer was fabricated without the truck. I also added Tricks' larger coolant tank. I also have a larger heat exchanger to add if I can ever figure out where to mount it and get any airflow.
Old Feb 9, 2012 | 06:24 PM
  #32
supersub's Avatar
Originally Posted by TIM Z
Im gonna ductape every other manifold port when i help him put the blower back on LOL!
Everything really turned out nice man!
11's no problem this spring, Def. wanna see how much this spacer helps.
Very cool write up, i thought maybe some more guys out there would share, maybe they camaro guys.??
Also Lucille, like asked what size TB did you have before the 102?
If i can gain a # of boost switching / modding to a 102 im going to really have to think about it
Here is 2 links to a camaro equipped with an RDS Plate. showing some extensive testing.
Maggie Max Project at JRE - Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com
JRE MAGGIE MAX STAGE 1 VS 2 RESULTS 727 RWHP - Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com
the phenolic reduces the actual blower temps by as much as 60* after several WOT pulls.
A cooler blower makes a powerful blower!!!
Old Feb 10, 2012 | 09:15 AM
  #33
Vortec350ss's Avatar
More air equalls more power regardless of boost. You can loose boost and gain power by increasing efficiency.
Thats what I thought, but I wasnt sure if it would effect the air velocity, etc.
Sometimes what seems like it should make sense isnt always right... I just had to ask!
Old Feb 11, 2012 | 09:59 AM
  #34
03sierraslt's Avatar
Well. Blower is back on, thanks to Timz for the help sitting this bitch in place.
Old Feb 11, 2012 | 12:26 PM
  #35
Celebration time. Couple German beers right off the plane.
Tim thinks my engine has a alcohol problem.
Old Feb 11, 2012 | 01:00 PM
  #36
1SlowHoe's Avatar
Destroyer of Transmissions
LOL @ the last pic.
Is that an 8-rib HD belt? If so, and that's with the RSD plate, can you PM me or post the part number? I need to get one so I can put my RSD plate on. If I remember right you are runnineg the 10% IW balancer as well?
Old Feb 11, 2012 | 01:18 PM
  #37
No, and No. Stock balancer and 6 rib
Old Feb 11, 2012 | 01:19 PM
  #38
it's alive
Old Feb 11, 2012 | 03:48 PM
  #39
TIM Z's Avatar
11 sec. Truck Mod
No better way to spend a snowy saturday.
That spacer really turned out nice, excited to see the results, She runs and sounds good now, i bet it will only get better.
Instant results are def. better clearence around alt. and upper radiator hose.
Damn nice working on an engine and not getting greasy!
And thanks for the delicious German Brew, im spoiled now, american wont cut it LOL.
Old Feb 11, 2012 | 04:02 PM
  #40
wkdivr's Avatar
Looks good! Makes me want to finish mine...............................if I ever get home from China! This job seems to have NO end!!!
