Another mod'ed TVS2300
Old Feb 7, 2012 | 06:23 AM
03sierraslt's Avatar
Default Another mod'ed TVS2300
Finished up my winter project, just have to put the blower back on. Thanks to Ray (Supersub) for the help.
Ports cleaned up and gasket matched
Old Feb 7, 2012 | 06:26 AM
Polished fuel rails as well
Before and after
Old Feb 7, 2012 | 06:28 AM
Little more space now below intercooler
Old Feb 7, 2012 | 09:12 AM
Rat Raceway's Avatar
Looking forward to your results!
Old Feb 7, 2012 | 09:26 AM
TX Tahoe Z71's Avatar
Very nice!
Old Feb 7, 2012 | 09:57 AM
BigKID's Avatar
Good winter project. I want to do the same thing to my KB to see if it will help heat soak on the upper manifold for better IAT readings. I hope to see you get the same results Ray did with the spacer.
Old Feb 7, 2012 | 11:21 AM
I hope to see similar results as well, I spoke with Ray about this quite a bit and he said he runs 1/2 on Camaro's and sees great results soo.. Mine is 1/2". One thing I didn't expect to hear is Ray said I should see 1-2lb boost increase as well, so I'll have to pulley up to keep boost constant so I can do a track run to compare apples to apples. The time in my sig was run to be a baseline for normal street use. I may see bigger gains if I raise the boost more.
Old Feb 7, 2012 | 05:31 PM
Me too. I got allot of hpt logs to compare before and after IAT's, MAP etc.
Old Feb 7, 2012 | 06:04 PM
Lucille's Avatar
Me to. Not sure which path Supersub is leading us down, but we're going to get there in a hurry.
http://i1145.photobucket.com/albums/...ett/photo1.jpg
http://i1145.photobucket.com/albums/...ett/photo5.jpg
Old Feb 7, 2012 | 06:15 PM
102mm?
Nevermind, seen your sig.
