another A/F ratio ?
Old Mar 18, 2006 | 01:27 PM
04Denali's Avatar
Default another A/F ratio ?
I know this has been asked before and I keep getting differant answers.
My A/F ratio is 11.3 to 1 at WOT from 0 to 100 mph. I am reading it with a scanner. Have a wideband but it is not hooked up yet. What is the best and safest A/F ratio for a Radix 6.0. Also I might as well ask this now. When I do the 90mm TB conversion will my A/F ratio change?
Thanks
Mark
Old Mar 18, 2006 | 01:34 PM
parish8's Avatar
single digit dreamer
a scan tools reported a/f ratio doesn't mean anything. you can look at the stock 02's and knock sensor and get some idea of how you are doing but a wideband is the way to go for sure.
11.5-12.0 is a good range for most boosted set up's. maybe 11.0-11.5 for anyone really pushing it hard. the 90mm tb will likely affect the a/f ratio.
Old Mar 18, 2006 | 01:39 PM
04Denali's Avatar
Thanks
Old Mar 18, 2006 | 02:06 PM
thunder550's Avatar
High on diesel fumes
I'll expand on his original question and ask....
Is 11.5-12.0 good only for WOT boost? What about part throttle boost? Reason I ask is that I just got my wideband hooked up, and the only time I see richer than 14.7 is at WOT. Is part throttle boost ok at 14.7?
Old Mar 18, 2006 | 03:29 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I generally take it to 11.5 anytime I see more than 100kpa (or when I cross from vacuum to positive boost). I used to turn on PE at 40% tps to cover any serious, pre-wot boost. Your enemy is still detonation.
Old Mar 18, 2006 | 03:30 PM
dewmanshu's Avatar
Moderately Differentiated
yeh but what are you calling WOT? What does your pe enable table say? If you are going WOT at 50% TPS, yeh you most likely are safe(disclaimer:everybodies setups have different needs) but if you aren't going WOT until 90%TPS then yeh...14.7 is not a good thing at 70% TPS. IMO. Maybe if your truck weighed 2500lbs.
Old Mar 18, 2006 | 03:31 PM
dewmanshu's Avatar
turboberserker beat me to the post...or just as he says!
Old Mar 18, 2006 | 07:32 PM
thunder550's Avatar
I think I mis-represented the question.
What I am wondering is should I be at 11.5-12.0 AFR any time I am into boost? I have a 2-bar MAP on the way and will be loading a custom O/S via EFI Live here pretty shortly, and will be doing SD tuning instead of MAF, so I want to figure out what the best AFR is for the different vac/boost readings.
Old Mar 18, 2006 | 08:29 PM
parish8's Avatar
i shoot for about 15.5-1 anytime i am not under boost. then as i cross 100kpa(0psi) be around 14.7 and by the time i am at 5psi be about 11.5.
Old Mar 18, 2006 | 08:42 PM
TurboGibbs's Avatar
With my 1 bar tuning on my 4.8 and 3.0 pulley we custom tuned the rpm. I was sooting up my bumper and killing my mileage everytime it would tip into boost while cruising up and down hills etc. Someone with a 6.0 with more low end grunt might not have this problem. Basically fine tuned the PE table to around 12.5-12.8:1 while accelerating at low rpm that I was seeing while cruising around 2000-2800 rpm. Above that the afr was in the 11.5 range.
Texas5.3_1251
Mar 5, 2016 08:10 PM
zblee
Nov 11, 2015 12:41 AM
old motorhead
Sep 29, 2015 08:22 PM
Boyes50
Sep 8, 2015 12:06 PM
