Am i expecting to much?
Old Jul 4, 2012 | 04:09 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Default Am i expecting to much?
Got a kb intercooled turbo installed on the sierra in my sig, shes being dyno tuned as we speak, so far she only put down 390 rwhp and 420 lb ft of torque, i was exspecting high 400 hp and tq at this point on 10lbs, is that exspecting to much out of a 6 speed 5.3 4x4 with 3:42 gears?
Old Jul 4, 2012 | 04:11 PM
foose04's Avatar
What type of dyno? What gear you doing pulls in?
Old Jul 4, 2012 | 04:16 PM
gamble686's Avatar
On a stock 5.3 that is pretty solid. If you throw a cam at it or a bigger motor that is a different story. Also considering the leveling kit you are probably on taller than stock tires. Which doesn't help.
Old Jul 4, 2012 | 04:24 PM
Piss Pumps for Sale
It is a bone stock 5.3, hes doing the pulls in third gear, hes going to do some more tuning in fourth tomorrow. Truck is leveled but still on the stock 275/65/17s. I honestly have no idea what kind of dyno hes using
Old Jul 4, 2012 | 05:08 PM
Gadgetized's Avatar
I would think it should be higher for 10 PSI. Does your tuner feel that it is close to being finished? Maybe timing is real low yet.
Old Jul 4, 2012 | 05:14 PM
Piss Pumps for Sale
Thought it seemed low for 10 psi aswell. Im not sure how much more he thinks he can squeeze out of it, whats a typical power for a 5.3 turbo? I know he had to screw with thr afr alot because of the maf being rught at the throttle body after the 90* bend
Old Jul 4, 2012 | 05:21 PM
Gadgetized's Avatar
Plus the DA is pretty bad today in most places in Canada I checked. Do you know what the AFR and timing are at?
Old Jul 4, 2012 | 05:34 PM
Piss Pumps for Sale
Yes it was definitely humid today, i cant say i know what the afr and timing were at, ill have to check with him tomorrow and then ill post back
Old Jul 4, 2012 | 05:44 PM
Piss Pumps for Sale
It wouldnt have to do with the maf sensor being after a 90 degree bend and my tuner having trouble getting the afr right because of it?
Old Jul 4, 2012 | 06:46 PM
slow67's Avatar
Gingervitis Addict
It sounds reasonable to me if its a mustang dyno and a stock truck cam/valvesprings.
