Alkycontrol/2 bar install question
Old May 20, 2007 | 08:45 PM
KySilverado's Avatar
Originally Posted by Stoichiometric
Well, I fixed up the wiring I already had, added a relay and everything runs great right now. I am using the only switched 12v pin I could find on the driver side fuse pannel to trigger the relay, the only problem might be that it becomes 5v when the key is in acc. position. I had some heater circuit codes pop up a while ago, I though that may be due to using that pin. I am up and running now though
Alkycontrol is great! The kit works flawless. I pulled some fuel out of the PE table to get an 11.5:1 AFR. I also bumped my timing from 17 degrees to 25. Before Alky, I would get a bit of knock at 17 degrees, now I don't have a hint and am running 25. The truck pulls much harder now. I can't wait to get it back to the track. Thanks TurboBerserker and KySilverado for the help.
You're welcome. It is a great kit. Several ways to account for the extra fueling. I pulled from PE also. Makes for a strange looking table but works great and then should still be able to modify enrichment rates to get what you want. I've never gone to 25 but do 22 IAT dependant and never see any KR at WOT.
trever1t's Avatar
2nd fastest 5.3 ECSB
25*, wow! I can't wait to see you in the 12's Henry. Congrads on the new cool mod!
Now pulley down!
Old May 20, 2007 | 11:10 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Glad you got it working!
Old May 21, 2007 | 02:32 PM
Breeze's Avatar
11 Second Truck Club
Dont tell Dewey but my Alky kit should be here on Fri (5/25) Hehe
Old May 21, 2007 | 02:44 PM
vanillagorilla's Avatar
So with alkycontrol kits, you can't tap the signal wire from the 2/3 bar MAP the PCM is using?
Old May 21, 2007 | 09:41 PM
Stoichiometric's Avatar
I believe you can get away with tapping the pcm's map sensor (MAP or MAF or any 0-5v), but I think the signal quality is reduced. Julio would be a good guy to ask this question if you were considering a kit.
Old May 21, 2007 | 09:44 PM
trever1t's Avatar
That's the problem we were having with my setup.
Breeze, I can't believe there is more left in your set-up. You'll love your kit!
Old May 21, 2007 | 11:01 PM
I AM A MOTHERF*CKER
The PAC needs to be on a stand alone MAP. I ran mine of a 3-bar that drove a guage for a while and Julio said "Well... okay, but..." and then I promptly switched it to a stand alone
At one point I had 4 MAPs in the truck... Right now, I'm down to 3 functioning MAPs, except I carry around a 3 bar MAP (that will migrate to PCM control when I find a compatible pigtail) just in case I find a guy on the side of the road selling 3 bar MAP pigtails or something (no idea why I carry it... I just do ).
Old May 22, 2007 | 10:23 AM
Blown06's Avatar
8 Second Truck Club
As for a 12v switched power sourced, I cut some insulation off of a thick red wire that runs from somewhere in the steering column to the back of the fuse panel in the truck. Then soldered the red wire from the meth kit to it.
Seems to work for me.
