aftermarket fuel rails with truck intake???
Old Jan 20, 2010 | 07:30 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
Question aftermarket fuel rails with truck intake???
anyone done this??
i have a set of aeromotive fuel rails and FPR... but want to run my stock truck intake (2005) and i have 60# Siemens Deka injectors
here is what i have...WILL IT WORK???
Old Jan 20, 2010 | 07:46 PM
wkdivr's Avatar
There aren't aftermarket fuel rails for the truck intakes. But, you can make the ones you have work, just have to fabricate you own stanchions.
Old Jan 20, 2010 | 07:57 PM
i have no problem fabricating mounts as long as it will work properly
Old Jan 21, 2010 | 10:49 AM
anyone else??
Old Jan 21, 2010 | 03:07 PM
wkdivr's Avatar
All the parts you have WILL work...............................but you'll have to do some adapting. Your truck, 05, right? If so, it has a returnless system. That means your FPR is inside the fuel pump module, inside the tank. The parts will work, but you'll have to modify your fuel bucket, removing the regulator inside there, run a new feed line, and regulate the fuel at the rails. That's the best way to go, but it's quite a bit of work.
Old Jan 21, 2010 | 08:21 PM
i have a 2000 v6 truck but i am putting in a 2005 wiring harness and intake w/ DBW
jdb11386
Dec 3, 2015 09:34 PM
Slammed96
Jul 27, 2015 07:22 AM
04450r
Jul 24, 2015 01:58 AM
GMCtrk
Jul 17, 2015 06:39 PM
jrplz
Jul 9, 2015 12:07 AM
