Afr up down
Old Oct 16, 2012 | 12:08 AM
franko98's Avatar
Default Afr up down
My afr is goin up n down between 12 to 18 under 2000 rpm when it does that my rpm also goes up n down about 100rpm I have checked fuel pressure vacuum exhaust leak and everything seems good what else could it be I just installed trick stage 3 it's on a 99 ecsb 6.0 80lb injectors 044 bosh inline sd tune
Old Oct 16, 2012 | 12:48 AM
Atomic's Avatar
I have a gauge for that
Does it do this while coasting down? If so its probably DFCO cutting fuel off. The 12 is probably when you are accelerating from power/boost enrichment....or I am misunderstanding what you are saying. When you are cruising at a steady speed, does it read around 14.6?
Old Oct 16, 2012 | 07:53 AM
tiffo60's Avatar
can you post a log/tune?
Old Oct 16, 2012 | 10:15 AM
franko98's Avatar
Yea anytime under 2000 it does it also when cursing its not as bad as in park the other thing when it's cold it runs a 100% with out any afr change when cold
Old Oct 16, 2012 | 10:26 AM
Alpinestar's Avatar
So it is doing this out of boost right? Did it start doing this all of a sudden or has it been doing this since you put the turbo kit on and got it tuned?
Old Oct 16, 2012 | 11:10 AM
franko98's Avatar
It started it after turbo and tune install as soon as I get into boost its holds steady every now n then it misfires a bit in boost 5psi
Old Oct 16, 2012 | 11:39 AM
nonnieselman's Avatar
have you checked fuel pressure while in boost?
Old Oct 16, 2012 | 01:27 PM
Gadgetized's Avatar
Can you give more info on your truck?
Old Oct 16, 2012 | 03:27 PM
franko98's Avatar
Yes fuel pressure stays at 58 my truck is a 99 ecsb z71 6.0 80e swap 3200 stall trick stage 3 triple 12 80lb injectors with a stock intank feeding the 044 bosh inline pump I hade everything installed except injectors and in ran fine so after I installed the turbo kit and injectors this started I also changed to a sd tune after the kit install
Isak81
Aug 29, 2015 01:44 PM
mz00516
Aug 23, 2015 12:19 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Ls3silverado
Jul 31, 2015 04:22 PM
