AFR readings?
Read the install instructions, you need to input type of fuel, afr sweep range and like said you need to calibrate sensor out of bung by turning it on for 5-10 sec, then install it and go do a low gear run in truck to rpm limit and lift completely off gas for about 5 secs. do it 2 or 3 times. this will finish calibration for rich side.
ALL ULL C
Feb 16, 2016 09:51 AM
