A340/FPR question
Old Feb 22, 2012 | 03:28 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Default A340/FPR question
Truck is a 2002 with a return fuel system. Has a sidemount Whipple and 60# injectors. Putting a A340 pump in the tank to eliminate the current frame mounted boost pump.
My question is, have the stock FPR's been working properly with the A340 pumps, or will an aftermarket FPR be necessary? Just curious if it can handle the additional flow(I'd think it could...)
Old Feb 22, 2012 | 03:40 PM
TIM Z's Avatar
11 sec. Truck Mod
You need a boost referenced FPR as im sure you know bud,
I wouldnt try it without one , not worth it to save 200 $.
Old Feb 22, 2012 | 03:58 PM
Stock pressure regulator is boost referenced. I'm still running the stocker on my own truck, but I have a Delco fuel pump in the tank, with the Maggie pump on the frame rail.
Old Feb 22, 2012 | 03:59 PM
Trying to determine if the stock regulator can handle the A340.
Old Feb 22, 2012 | 04:29 PM
kbracing96's Avatar
Yep, handles it just fine I've got an AM340 with a hot wire kit and never an issue.
Old Feb 22, 2012 | 06:27 PM
TIM Z's Avatar
11 sec. Truck Mod
Hmmm cool to know, did you have to mod it to adjust it Roger/ Kyle ??
Wasnt sure as i use a NNBS fuel rail.
Old Feb 22, 2012 | 07:50 PM
03sierraslt's Avatar
Tim, It should work in your tank.
Old Feb 22, 2012 | 08:04 PM
kbracing96's Avatar
Nope, not a bit. FYI, the returnless uses the same regulator only its mounted in the fuel tank instead of on the rail.
Old Feb 22, 2012 | 09:46 PM
Beatdown Z's Avatar
Laid Back
I have the same set up as Kyle and although it doesn't have much runtime, it's been doing just fine.
Old Feb 22, 2012 | 10:31 PM
Mangled03gmc's Avatar
Baltimore Whore
I am running a bosch 044 pump on the oem FPR, have no FP issues. So i would say yah it will work
