99-06 TVS 1900 and 2300 Difference's...
Old Apr 18, 2009 | 12:59 PM
bgray's Avatar
TOTM: June 2007
Default 99-06 TVS 1900 and 2300 Difference's...
Is it just the overall size of the unit ???
cammed, bolted, trans, and rear end on the truck have all been done, with the possibility of the 5.3 being replaced with a 6.0 downt he road...
does the tvs2300 sound like the proper route
Old Apr 18, 2009 | 02:19 PM
BlownChevy's Avatar
blownerator
25 Year Member
what are your HP goals?
Old Apr 18, 2009 | 04:25 PM
bgray's Avatar
TOTM: June 2007
I ahve no specific goals perhaps, But if the tvs 2300 is usuaable then i will go big...I jsut dont want to get a blower that is way to large for factory crank and head
Old Apr 19, 2009 | 07:38 AM
BigCountryx's Avatar
how much boost do you plan to run? The 2300 will likely put out about 10 lbs (maybe more) on that 5.3 pullied way up. And it will boost a little slower... not necessarily a bad thing mind you.
Old Apr 19, 2009 | 09:02 AM
bgray's Avatar
TOTM: June 2007
I jsut dont want to a buy a blower that will be mazed out right away...like something that if i put on a build 6.0 i still ahve some room to move with it
Old Apr 19, 2009 | 09:14 AM
I hear you bro....After lots of discussion about my goals and expectations, I went with the 1900. Even if I go 370 (I don't want a stroker) I don't plan to run more than 10-12 lbs of boost so I went with the 1900. An 8 rib setup would put me past what I want out of the blower and the TVS doesn't mind being spun up... the IAT's are not an issue like they were with the radix. I just felt that it will work well with my setup and the 2300 would have been wasted on me. Call Joe at Leftcoast32. He will work it out with you.
kainzien
Nov 10, 2023 11:37 AM
bagged7104SS
22
Oct 24, 2015 06:14 PM
Velocity1
Oct 12, 2015 10:39 PM
blown 04
Oct 2, 2015 07:33 AM
