90mm tb ? eldebrock intake ?
#121
80hp?? i had a nice talk with jeff at induction. he asked me about my cam specs and from his point of view my cam probably has a little too much overlap if i am going to run it thru exhaust. if my exhaust presure is 60psi and my intake presure is 20psi and i have some valve overlap i can see a real power stoper. i wider lsa might fix me up or freeing up the exhaust.
i think the crazy power will come with he cut outs. with just the intake i dont know what it will do.
#122
Jim I am going to agree with Jeff but you might want to look at this thread near the bottom there is a alot of good info on turbo cams and that overlap is not always that bad
http://www.turbomustangs.com/smf/ind...?topic=66794.0
#123
#127
i have been out a couple of times trying to tune but am running into some computer issues. i think when i put the batery in the back it changed my grounding enough to cause some problems. i tried an extra ground strap from the motor to the body and it got a lot worse so that kinda tells me i am on the right track but the wrong area.
you know i will post up some performace info once i get thru this and start hammering on it.
#128
How do I change this text
hey Parish I have one QTP cut out, and it don't leak yet, its been on for about four-six months with me driving almost everyday. but it doesn't see as much pressure as your would when it is closed because of it's location behind the turbo. The exhaust just has to go over a axle and through a muffler......
#129
