90mm Radix alterations
Old Mar 9, 2006 | 07:27 PM
  #21
BigBlackAv's Avatar
There will be lots of people to thank for making this possible, but, for this 1st part, getting it mounted, it is BigTex.
Also a bit of a tip, i was able to cut my J tube w/ out removing it....i have a hole saw set and put a 3-5/8" on the mandrel and then put a 3" over that and the 3" rides inside the original hole and guides the 3-5/8" to cut a perfect hole...no fuss, no muss! Here are some pics!
Thanks BigTex!
Attached Thumbnails 90mm Radix alterations-img_0023-medium-.jpg   90mm Radix alterations-img_0024-medium-.jpg   90mm Radix alterations-img_0028-medium-.jpg
Old Mar 9, 2006 | 07:37 PM
  #22
ItsJustMo's Avatar
Nice BBA! Great tip about the hole saw!
Old Mar 9, 2006 | 08:06 PM
  #23
Vdrumright's Avatar
That is a great idea.............
Old Mar 9, 2006 | 08:19 PM
  #24
BigBlackAv's Avatar
I know....it took maybe 10 min to cut and it barely needs some touching up w/ the dremel...it worked out sweet! Thanks.
Old Mar 10, 2006 | 07:16 PM
  #25
krambo's Avatar
The innovation everyone is adding to this modification is fantastic. Great job!
Anyone else?....
Old Mar 14, 2006 | 10:43 PM
  #26
BigTex's Avatar
Nice touch with the hole saw. I like that. Thanks for adding that info and your pictures to my post here BigBlackAv.
Old Mar 18, 2006 | 02:53 PM
  #27
BigBlackAv's Avatar
no problem, it wouldn't have been possible w/ your pics...thanks again!
btw, my tac is on backorder (supposed to ship on monday) and got my wiring harness last week...hopefully i can get it on and running by next weekend!
Old Mar 23, 2006 | 07:09 AM
  #28
JimS's Avatar
I had a machinist make my flange and then weld it on to the j tube but it didn't have the groove machined for the gasket. I used the Loctite gasket maker, #510, and although it's expensive it has worked just fine this first 2 weeks of use.
Old Apr 1, 2006 | 06:21 PM
  #29
BigTex's Avatar
You guys who have finished the 90mm mod - what are your impressions? I changed so many things at one time that I can't say exactly what gains I had from the 90mm TB alone. I'm just curious.
Old Apr 1, 2006 | 08:41 PM
  #30
nochance's Avatar
I can see why your the man.....
This is one of the best post I have seen....
Somebody buy him a drink for this....
